Results 1 to 10 of 22
Thread: Airbag ECU fault codes ??????? ?
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default Airbag ECU fault codes ??????? ?
    iv had my airbag light come on for some time... was told the airbag ecu was faulty so purchased on out of a vectra bein broken
    airbag light still on so.. been and got the fault code.. and its many
    B0012
    B0012
    B0014
    B0015
    B0016
    B0019
    B0020
    B0021
    B0022
    B0023
    B0084
    B0085
    B0086
    B1000 ECU Malfunction
    Confused as f as iv not twanged the car.. it all started when the Mrs drove it quiet a few miles in one week
    all iv ever done to the car is cut the ignition live off from the rear lighter socket and run a perm' live from the battery
    Also iv got both Side lights out at the min as they are so friggin hard to get to to change
    If someone can annalise this pls
    Tim
    shropshire
    bump
    shropshire
    anyone know what these codes mean ??
    shropshire
    anyone know what the codes mean ?
    B0012
    B0012
    B0014
    B0015
    B0016
    B0019
    B0020
    B0021 - Pass Side Airbag Squib (circuit low voltage) ? i think
    B0022
    B0023 - Pass Curtain Squib (circuit low voltage) ? i think
    B0084
    B0085
    B0086
    shropshire
    B0012
    B0012 Passenger Frontal Stage 1 Deployment Control (Subfault)
    B0014
    B0015
    B0016
    B0019
    B0020 - Passenger Frontal Stage 3 Deployment Control (Subfault)
    B0022 - Left Side Airbag Deployment Control (Subfault)
    B0084 - Passenger Seatbelt Load Limiter Deployment Control (Subfault)
    B0085 - Second Row Left Seatbelt Load Limiter Deployment Control (Subfault)
    B0086 - Second Row Center Seatbelt Load Limiter Deployment Control (Subfault)
    B1000 - Immobilizer Control Module Malfunction
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Quote Originally Posted by Steven T Davies-Moss View Post
    B0012
    B0012
    B0014
    B0015
    B0016
    B0019
    B0020
    B0021
    B0022
    B0023
    B0084
    B0085
    B0086
    Tim
    the new airbag ECU you put in have you had it reprogrammed to your Main ECU?
    shropshire
    Quote Originally Posted by slipperysam1984 View Post
    That will be the problem then.. although im guessing that if it needs tech2 then ill find problems clearing it from its old vehicle as iv no details ???
    shropshire
    iv just realised.. it was the security chip that they transfered over when i sent the old and new donor airbag ecu to have the 'data transfer'
    Mmmm... confused.com
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Should reset easy enough with tech 2.
    As for side lights drop bumper an take lights out it's easier
    shropshire
    Quote Originally Posted by CritchvxD View Post
    VX dont make things easy do they
  1. Airbag error codes
    By killa_uk in forum Vectra C / Signum Troubleshooting
    Last Post: 9th November 2013, 12:42
  2. Airbag Fault Codes
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 00:49
  3. what would cause all these airbag fault codes?
    By krazylegz in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 18:36
  4. Can someone please help. AIRBAG FAULT
    By Bigg943 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2011, 22:32
  5. Airbag ECU fault
    Last Post: 2nd February 2011, 23:22
b0019 fault on a vectra
greska b0012 -oe driv air dquib cire
vauxhall airbag code
b1000 airbag code opel
b0012 airbag code vauxhall
vectra c eroare b0023
Vauxhall DTC B0085-02
vauxhall airbag fault codes
kod opela greska b1000
Vauxhall B0086
opel astra b0019
opel vektra 2004 feilkode b0019
B0021 vauxhall
insignia airbag problems
B0012 vauxhall
insignia code airbag module to car
https:www.vectra-c.comforumshowthread.php137321-Airbag-ECU-fault-codes
vectra c b1000 fault code
b0086 airbag code VAUXHALL INSIGNIA
airbag sequence vectra c
