Thread: After market radio question
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default After market radio question
    If I fit an aftermarket radio to my facelift vectra how do you set the clock as it currently set via the standard head unit or does the RDS set the clock?
    Full Member
    South West
    When i had an aftermarket radio, i had to remove it, plug up the original and then set the clock. Only takes a few mins to do, and considering its only twice a year not too much hassle either. Or get it changed via Tech2.
    I think some of the newer radios on the market have the ability to update the clock via RDS, but no idea which ones.
    gwent
    It all depends what head unit you fit I fitted a kenwood with a kenwood remote steering wheel control harness and I can change the time with it .I also did it with a alpine head unit with alpine harness so if you fit a after Market head unit get the proper harness
    Limavady, N.I
    Mileage : 121000
    I have a JVC KD-G441 so would you have any idea what I would need to keep the clock and steering wheel controls?
    gwent
    See if jvc do a harness for the car I would go to you local ice dealer and talk to them see if they can get one
    Woodbridge
    I have a kenwood one and it does not do it
    gwent
    If you buy a kenwood steering wheel control harness about £80 not a cheap autoleads won you can change the clock time
    Woodbridge
    Quote Originally Posted by wayne10244 View Post
    Got that one, still dont work. Are you talking about full canbus?
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    I have a clarion unit fitted using connects2 steering wheel interface, this allows you to change the time using the steering wheel controls. Although the downside is the radio only works with the ignition on. instructions here http://www.connects2.co.uk/Instructions/SVX002.PDF
    Woodbridge
    Thanks for the link. Will give it a go.....
  1. radio question
    By kevin18050 in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2013, 13:50
  2. after market switch connection question
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 13th April 2012, 21:40
  3. after market radio
    By 06 vectra in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2008, 19:36
  4. After market radio fitment
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 01:05
  5. Radio Question
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2007, 10:16
