Thread: no clutch!!!!
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default no clutch!!!!
    Hi I had a prob with this today,pulled over and stopped car to load boot up and then went to start car and just made a clank as if misfired, it didn't start it took couple goes then it did.
    The clutch pedal was very easy to depress went to pull away and nothing car don't move.
    I looked to see if I had put it into 1st gear and it was,I Tryed it again and the same thing don't move,at this point I was getting annoyed as just paid out for alternator and fitting couple weeks ago. I stopped car and restarted it and clutch pedal went firm and the car pulled off as normal. Now the pedal feels harder than before or it might be
    me
    Is this clutch on the way out or is it normal sometimes,the car seem ok now with clutch pedal half way before it bites, car is s 1.9. 150bhp
    Sounds like the DMF has failed, taking the clutch with it
    As a 2008 car it may still be under OE warranty, if so book it in NOW
    If not, then look at a third party warranty that includes cover for DMF and clutch
    warrenty ran out in april!!!!!!!! its working ok now get all gears and running good, qyestion is will it go again???????
    Quote Originally Posted by mitch View Post
    How long is a piece of string
    I first reported a suspected failed DMF in 2007 and it wasn't until 2009 when it finally failed completely
    Nov 2010
    doncaster
    if you push clutch down about 1 to 2 inch does it make a noise
    No it makes no noise ,
    Regular Member Exclusive BV's Avatar
    West Midlands
    sounds like a sticking clutch bearing to me, it could be hanging up and not releasing properly
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    A bust flywheel will immobilise the car until it is replaced.
    Quote Originally Posted by Exclusive BV View Post
    I agree here, sounds like the throughout bearing.
    Gazza4
    Is it ok to drive, seems ok through all 6 gears, its just the fact that when it happened it was in 1 st gear and car didn't move as in neutral and pedal soft to press. It's been fine since Monday.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
