Thread: emissions warning light cdti sri150
    Regular Member chrisknights's Avatar
    Feb 2011
    brighton
    Default emissions warning light cdti sri150
    hi guys and girls , i have a problem i have changed my side light bulb as it had blown , took air filter box out and changed bulb and put every thing back , when i when to test out side light it worked but found my emission light on and staying on , i went for a 5 minute drive and its still on ,what should i check and i plugged every thing back in ,
    West
    it could be just a coincidence, i would get the codes read & take it from there
    Feb 2011
    brighton
    is there a way of me getting the code or do i need to go to a garage ?
    Feb 2011
    brighton
    just to update , i solved the problem after reading throught some threads on here , it was the EGR valve , i took it off and gave it a good clean , but will later on do the mod where you drill a 3mm hole and every now and then spray some wd40 in there to stop it sticking , as i only drive short journeys there was a build up of black sut in the EGR valve , the emissions light now turns off , so it alawyas pays to read throught others posts ,
  1. Emissions warning light on
    By peterb11 in forum Engine & Drivetrain
    Last Post: 18th March 2011, 17:03
  2. Emissions Warning Light
    By fifesri in forum Engine & Drivetrain
    Last Post: 14th September 2010, 20:58
  3. Emissions Warning Light
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2010, 21:12
  4. Emissions Warning Light
    Last Post: 28th August 2010, 19:23
  5. Emissions warning light
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 21:19
vectra c emissions warning light
