Thread: low beam problem
    Regular Member vectra_'s Avatar
    australia
    Default low beam problem
    hi everyone, the problem is when i turn the car off i pull the high beam stalk to make the low beams come on for 30 seconds but when i do that what happens is, the left low beam comes on and the rıght low beam sometime does but most of the time it doesnt... i dont know why this happens, ive got 6000k 55w hids fitted from hids-direct
    Regular Member farley2708's Avatar
    antrim n.ireland
    think its bad for the ballasts,switching on/off with no power on (red ignition lights on dash) or when the cars running.i take it they come on ok when your car is running/ticking over?
    australia
    Quote Originally Posted by farley2708 View Post
    yes its fine when the car is running...and if i turn the lights on THEN start the car, the right low beam stops working
    6 Post(s)
    Quote Originally Posted by vectra_ View Post
    Sounds like you've either got a poor electrical connection or a lazy ballast.
    Full Member Teapot's Avatar
    woodbridge, suffolk
    73 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Have you configured the system for HID lights? When set for halogen bulbs the UHM (UnderHood electrical Module) modulates the power feed to the bulbs when the engine is running so that the nominal voltage never exceeds 12v - they did this to extend bulb life.
    Most HID ballasts don't like this and it can cause strange problems like you are experiencing.
    Anyone with a Tech2 or an OPCOM can do this - only takes a minute to do.
    Hope this helps!
    australia
    Quote Originally Posted by littleteapot View Post
    Hope this helps!
    so what do they have to do with the tech2? if i take the car to a mechanic and tell him whats going on would he know what to do with tech2?
    thanks to everyone for the replies very helpful
    woodbridge, suffolk
    73 Post(s)
    Trim : Design+
    Mileage : 101000
    The mechanic would need to competent in the use of the TECH2 or OPCOM. Basically he would connect it to the diagnostic port of the car (under the ashtray), log into the underhood electrical module and change 'Xenon headlights fitted' to YES. Job done.
    The hard part will be finding an independant mechanic with either a Tech2 or OPCOM. You may have to go to the stealers and face the primates who won't understand what you want done!
    australia
    last question...
    does the battery have to be disconnected?or after activating the xenon headlight fitted option to yes, does the battery have to be taken off and put back in to reset anything?
    woodbridge, suffolk
    73 Post(s)
    Trim : Design+
    Mileage : 101000
    No, the effect should take place immediatly. No need to disconnect the battery.
  1. Hid beam
    By dannyp in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 13:16
  2. Better Dip Beam
    By insignia28 in forum Styling
    Last Post: 6th July 2011, 19:03
  3. Full Beam/Dipped beam
    By ontoplums in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2011, 18:06
  4. Dip Beam
    By dc6839 in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 17:53
  5. High Beam Problem
    By bigtime5001 in forum Troubleshooting
    Last Post: 27th September 2009, 11:17
