Thread: 3.0 cdti EGR location
    Apr 2011
    Durham
    Default 3.0 cdti EGR location
    Hi there i am suffering from a few problems and could do with some advice.
    Firstly where is the EGR valve located on my 3l diesel vectra (04) as i think i have a problem with this also is it worth (cleaning, Blanking or replacing)
    and if replacing does anyone know anywhere cheaper than £350 cheers only bought the car 2 weeks ago i think previous owner knew and didn't let on thanks again
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If I remember rightly its on left hand side. Just under the ecu plate.
    Should make sense when looking at the engine with plastic cover off?
    What problems are you having?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Not worth cleaning as it doesn't help...not on the 3.0CDTi.
    A faulty EGR will cause massive black smoke under full throttle, and when it's really broken the car will drop into limp mode.
    Apr 2011
    Durham
    Default EGR Location
    My car went into limp mode with engine management light on but when i had it read the ecu fault was with the maf sensor but that is ok, so had codes reset and was clear all week i did 200 miles around town no probs. Set off for london did about 130 miles and light came on again and went into limp mode again using cruise could stay at 70 on motorway until i got there had had RAC out. Fault was now egr did 15 mile back on again so made it home (via cruise) not wise i know but had car full. got faults read again egr valve reading again cleared it and ok again today, will replace if need be but other people are saying you can blank it off with no adverse efects for mot as NOX levels are not measured in uk. heard lots of different stories about blanking (plate with holes so no engine light, or remap via "regal autosport" with plate to cure same probs) anyone know for certain the cheapest way out don't really want to spend £500 when ive only had it 9 days any ideas would be great thanks.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Blanking doesn't work on the 3.0CDTi as it will show a manifold pressure fault code.
    When the car is not in limp mode, does it smoke black (heavy smoke) when you give it a boot full? If yes, your EGR is faulty I'm afraid.
    If it was a boost related problem (blown hose) the code reader would pick on that, not the EGR, same goes for vacuum related problems.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    This is where the EGR is located just so you know Fiddly to get to, even fiddlier to put back together...The red circled bit is the hardest to remove, well the connector on it is.
    Apr 2011
    Durham
    Thanks for the answers and pic, in answer to your question no it does not smoke bad at all only once i have seen black smoke from the exhaust and that was when engine light was on but not since then
    Apr 2011
    Durham
    Does anyone know where to get the best deal either on used or new part i think the part number is 98030644 cheers for all info, i need to get this sorted as the car is for work and i travel to london every week for that without my car everyone is out of work cheers
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Try auto Vaux
  1. cdti 120 rail location
    Last Post: 12th November 2012, 23:40
  2. 1.9 CDTi 150 Throttle Body Location
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 08:12
  3. Crank Sensor location cdti 150
    By kirkyoke in forum Engine & Drivetrain
    Last Post: 7th September 2009, 19:10
  4. 1.9 cdti 150 Turbo Location
    By bgm46 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 20:36
  5. location and removal of a cdti sxi 120ps ecu
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2008, 19:08
vectra 3.0 cdti egr valve location
where is egr valve on vectra 3.0 site:www.vectra-c.com
signum 3.0 cdti egr valve location
