Results 1 to 10 of 23
Thread: P1312.. help?!
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Default P1312.. help?!
    Searched here cant find any reference to it? Anyone help please
    Vectra 2007 Z20NET
    From what i can work out in Saab forums it seems to be misfire problem or co sensors or a DIC whatever that is?!
    Thanks in advance
    Oct 2006
    southampton
    15 Post(s)
    P1312 Ignition Coil "B" Primary/Secondary Circuit
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    according to the GM obd2 fault listings its
    Ignition coil B primary/secondary circuit fault
    Dohn hes done it again
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by bobssignum View Post
    Age is on my side Bob lol.....
    oh well.. I tried..
    So in idiot language for me.. the coil pack on top of one of the spark plugs have gone belly up?
    leeds
    Did you ever get to the bottom of this?
    I have just had my emissions light come on (pic of an engine) while driving. Read codes and have the same one. It means random/multiple cylinder misfire.
    I thought with the emissions light on possibly the lambda sensor is playing up and mucking up the mixture? A duff mixture would surely cause a random misfire.
    Having said all that the car drives spot on and I have not felt any misfiring! In fact the light has now gone out, I have cleared the fault code and it has not come back. It might come back though...
    oh well.. I tried..
    No the light went away and stayed off.. now having said that bet it comes back lol
    Regular Member Alex the Russian's Avatar
    Jun 2011
    Moscow, Russia
    confused
    I also have that p1312
    no other codes detected
    spark plugs are new, air filter is clean, wires seem to be ok,
    petrol is 'Moscow 98' which is closer to european 95, but quality seems to be ok, too
    after clearing this fault by BSR PPC it comes out again after 10-15 miles
    the thing is that I can't feel anything unusual driving on stock software
    but if stage 3 software is set up car starts twitching on about 3-3.5 rpm and misfire is felt very clearly
    any ideas?
    Jun 2011
    Moscow, Russia
    guys, your ideas are needed
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    one or more of the coils has probably failed and needs to be replaced, i got secondhand coils from Neo to sort mine when it did it.. The DIC is another name for the ION module (sometimes referred to as the 'cassette') which the coil harness connects to on the righthand side of the engine. on the old saab engine this was a known point of failure but is rarely an issue now, you can also buy used modules for this but they are not so common and can be quite expensive...
