Results 1 to 10 of 15
Thread: Misfire
    Jul 2009
    letchworth
    confused Misfire
    Hi guys,
    I have a strange problem with my 1.9 cdti. It does some misfire between 1500 and 2000 rpm especially when in low gear (second or third) but sometimes with fourth as well. I went to my garage they cleaned some pipes and they carried out diagnostic but no fault codes stored in ECU. They have also checked the EGR valve operation and voltage - all working correctly. They have also checked all turbo vacuum and boost pipes and they added some fuel treatment to the tank.
    The car is much better now but still not 100% okay - not as it was a few weeks ago.
    Mileage 99k, all services done, I just had a major service including new timing belt kit and cleaning away carbon contamination from diesel injector body.
    HELP!!!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    forgive the ignorance but were the glow plugs changed?..are the leads seated properly?..
    Jul 2009
    letchworth
    Hi,
    Thanks for your interest in my case!
    I have no idea. They supposed to be changed if they were part of the major service, I will ask my garage.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Is it a misfire? Or is it a hesitation (kind of judder/kangaroo)??
    Is it only on light throttle changes?
    Do you get it when you put your foot down?
    Its sounds similar to what a lot of people get when the EGR/throttle valve/inlet is all gunged up?
    Jul 2009
    letchworth
    YES!!! It is a hesitation! For a moment or so.
    Sometimes I have the feeling the throttle doesn't respond (and I have to push it further down) some other times it is a hesitation. It is confusing because most of the times is ok and some other times is so little you think it is my idea but then comes the hesitation for the split second (like an instant on-off) and you think yes it's not me - something is wrong!!!
    Jul 2009
    letchworth
    Also Marky,
    when I put my foot down 99% accelerates fast but some few times responds like has not enough air (breath). Only between 1500 and 2000rpm and with low gear (second or third).
    My garage seemed confused.
    If you or any other guy could help...
    Many thanks mate!
    Jun 2006
    North West
    It sounds like the EGR blocking the breathing. Very common on the 1.9 diesels and there isn't a definite fix for it.
    You can help reduce the problem by cleaning the EGR valve, Boost (or MAP) sensor, throttle valve and inlet manifold.
    Replacing the EGR may fix the problem as the plunger inside gets stuck.
    Also adding EGR flow reducing gaskets from FIAT can help.
    http://www.vectra-c.com/forum/attach...7&d=1232829228
    Some people have started to block the EGR using a blanking plate but this will make a light come on on the dashboard as the car thinks it has a faulty EGR. So you need to get the car into a chip tuning company to remove the EGR valve from the cars computer.
    Basically the EGR puts exhaust gases (and therefore soot) back into the engine through the inlet manifold. This sooty gases then mixes with some oil in the inlet tpoo the engine and gunges everything up.
    The EGR valve is opened and closed automatically by the ECU and it seem that the jerking/hesitation ocurrs when the EGR is opened or closed.
    Its an emissions reducing device but it tends to cause more problems than it solves.
    Might also be worth checking that your injector plugs are seated correctly.
    Post number 12 and onwards: http://www.vectra-c.com/forum/showth...t=63811&page=2
    With the engine running see if there is any play in them (Push them in don't pull them out) and see if the car sounds different.
    Jun 2007
    chesterfield
    Hi guys,
    I'm also getting a similar problem, all the cleaning in the world hasn't seem to fix it, and the EGR is less than 6 months old.
    I'd herd that VX have an ECU update that they apply if fitting a new ECU, mine wasn't fitted at a dealer so that update wouldn't have been done.
    Is it worth a punt on having the update done ?
    lincolnshire
    i'd wager they did the upgrade at the time bud
    Jun 2007
    chesterfield
    it wasn't a VX dealer that fitted it...
    or if it was i want to have serious words with them, they used liquid gasket instead of replacing the seals, and then didn't use washers on one of the bolts, so it bottomed out in the casting and wouldn't hold the plate flat (soot marks all over the place from where it was leaking gases) anyway thats a whole different story
  1. misfire on 1.8
    By Lozza in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:57
  2. misfire?
    By ivesy in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:55
  3. V6 misfire?
    By lencuff in forum Engine & Drivetrain
    Last Post: 16th November 2010, 21:10
  4. 1.8 misfire
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:09
  5. Misfire
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2006, 16:30
