Results 1 to 3 of 3
Thread: turbo boost fault 30ltr cdti
    Regular Member 30ltr nutter's Avatar
    dunstable
    Default turbo boost fault 30ltr cdti
    hi guys my 30cdti vec has a turbo boost fault it seems to be in full boost and has fault codes 0235 and 1571 , 0235 says boost pressure sensor circuit a malfunction and 1571 says brake light switch malfunction .
    the boost sensor has been changed and vac pipes checked and turbo varibale vanes cleaned . would the brake pedal swith have any bearing on the boost control the brake lights are working ok and the cruise control works ok any advise would be great many thanks in advance
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Been a while since you were on here
    Now I don't exactly remember the fault code on my old 3.0 (definitely wasn't MAF related), but I had problems with boost too. I cleaned the MAF sensor and it was fine for a bit, so you could try that.
    dunstable
    Quote Originally Posted by Celes View Post
    hi i havnt been on the site for a bit i have read a few posts from time to time but ive been busy ect thanks for your reply i will check the maf the car has been fine since i had the fault with the stealers mucking up the belt tensioner . ive stripped the turbo ect that was ok just sems to be over boosting but it is dam quick at the moment just dont want to burst the intercooler ect
  1. What turbo boost would I expect on a 1.9 CDTi?
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 23:14
  2. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  3. engine misfire 30ltr cdti
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 19th July 2009, 01:54
  4. Bit of help please (Turbo Boost Control Fault)
    By TinFish in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2008, 20:06
