Results 1 to 10 of 13
Thread: anyone modded top of air box shorten the pipe inside
    Worksop
    Default anyone modded top of air box shorten the pipe inside
    looks like u could cut back the pipe flush with top of box anyone tried this?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't it will hamper performance and cause all kinds of problems as the airflow will be erratic through the MAF. If you really wanna try it see if you can get the same airbox as yours on ebay and experiment with that.
    Gazza4
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I did it with my Vec 3.2 and my Corsa Vxr, never had any probs
    Worksop
    Quote Originally Posted by Kev_A View Post
    u done it to ur turbo?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Someone done it to their car and quickly had to put it back the way it was as the car ran badly.
    Gazza4
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Even after market Filters have a runner inside to align the airflow over the MAF so i'd leave in be IMO. It also instigates the spinning affect inside the intake so speeds the airflow up which in turn helps with torque. Yes cutting it off may give you better top end as more volume of air can travel, but at a lower speed so to the loss of torque, so unless to want top end BHP numbers on a RR or drive around on the red line, keep it. Its there for a reason
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I cut it along the length of the top tube Mark,only the bottom half of the top tube,so it still catches the air i thought.
    I can't say i've noticed any difference at all to be honest,but i might look for another air filter box top to put back on to see if anything is different again.
    Worksop
    Quote Originally Posted by Aikon58 View Post
    u mean u cut the tube in half Scott leaving the top half in place?
    Engine : Z20NET
    Quote Originally Posted by tomo41 View Post
    Don't have an airbox on my turbo, got a BMC CDA
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Yes mate,i cut along the length of the top tube inside the lid of the airbox along the center,so the length of the tube is the same length,but there is only the top half of the tube left,i thought i'd try doing it that way so the air will come in the airbox,through the filter and be caught by the top half of the top tube,and wouldn't have so far to go,to go through the maf,so getting the air in quicker.
    I have no idea if my idea worked or not,as i havn't noticed any difference to be honest.
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. 2.0t vacuum pipe inside diameter?
    By tomo41 in forum Petrol Engine related
    Last Post: 15th June 2011, 19:23
