Thread: Strange Heater Blower problem
    May 2011
    London
    Default Strange Heater Blower problem
    Hi
    First of all, I wouldn't waste your time if I hadn't already read all of the stickies and related posts to this problem.
    Basically, the fan blower will only work on Speed 4.
    I have replaced the blower resister pack and the problem remains.
    When you switch to Speed 1 & 4 you can hear (and feel) the blue relay click.
    I have checked the motor which is clean, dry and spins freely.
    Having read a similar thread someone mentioned "one of the 4 relays", and I only seem to have 3. Is this usual on a manual 4 speed air con ??
    (2005 1.9 CDTI SXI)
    Many Thanks
    Sep 2009
    Glasgow
    possible that it blew again, they have been known, try the maplin thermal fuse fix.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    sounds like the resister
    May 2011
    London
    Can't be. I have 2 brand new resister packs and the original with the new maplin resister all with the same result !!
    Oct 2009
    Sandwell
    try another relay off a vectra
    May 2011
    London
    Is it only the blue relay that relates to the blower ?
    Regular Member djr69uk's Avatar
    Midlands
    Yes it is. Give it a go as that was the problem for me. The click for 1 was present but not as loud as the click on 4. I took the relay apart and there was some crap in it blocking the contact. Worth a look fella!
    Midlands
    Here we go... read this thread for more info. In summary, I think it's either the relay or the BCM for you.
    http://www.vectra-c.com/forum/showthread.php?t=56294&highlight=heater
    There are two relays... K4 and K5. The blue rectangular one is the one that controls speed settings 1-3, the other controls speed 4.
    Hope that helps.
  1. Heater Blower Strange Problem - Help!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2014, 22:38
  2. '02 GSI, heater/blower problem
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 12:54
  3. heater blower problem
    By manunut1969 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2010, 02:17
  4. Heater / blower problem
    By lacorbiere in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd March 2010, 14:24
  5. Blower / Heater Fan Problem
    By zealot210 in forum Bodywork & Interior
    Last Post: 11th January 2010, 17:38
