Thread: crankshaft sensor
    Jun 2007
    leeds
    Default crankshaft sensor
    ok could enyone help before i shell out for an auto electration on tues
    the problem is the spanner light came on so i did the pedal trick and also bought a obd11 scanner and both confirmed it was the crankshaft sensor
    so i replaced cancelled the codes but they came back on again,having looked on here and the net someone had asimular problem and it turned out to be the sensor was not seated properly. so ive just been outside and taken it off again and it was covered in oil ( is this ok) cleaned it put it back in and it all worked ok starting the enguine and stopping it several time when i went to pull the car round the front it came on again
    2 question really
    1 should the sensor be couvered in oil
    2 i onle replaced the sensor could it be the cable that needs replacing
    or any othe ideas
    thanx guys
    p.s 1.8 petrol on a 02 plate
    Quote Originally Posted by valhalla View Post
    No, there should be no oil
    It is clearly escaping from somewhere so you need to trace it
    The oil is then getting in the way of the sensor, there was probably nothing wrong with the original, so refit that one once you have sourced the oil leak
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Nope, looks like youve an oil leak, maybe from a cam shaft oil seal. When I did the timing belt on mine the area was bone dry.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    My inlaws was covered in metal fileings aswell. Assume this is not a good thing. But he's still getting hassle with his running rough and showing a code for the sensor.
    Jun 2007
    leeds
    ok thanx for the quick replies i will cancel the sparky ( for now )
    and get it into the garage
    Jun 2007
    leeds
    ok got it into the garage and the machanic said the crank shaft sensor sits in the enguine block
    it will have oil in it
    so ive rebooked the sparky
    this ir turning into a nightmare
  1. crankshaft sensor
    By liam8282 in forum Engine & Drivetrain
    Last Post: 18th September 2011, 13:29
  2. Crankshaft sensor
    By Dimscreen in forum Engine & Drivetrain
    Last Post: 19th April 2011, 10:27
  3. crankshaft sensor
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 20:36
  4. crankshaft sensor on v6
    By hugh in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 15:58
  5. Crankshaft Sensor
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2008, 23:21
