Results 1 to 10 of 15
Thread: 2.2 direct oil leak
    Regular Member noel.nev's Avatar
    Pen-Y-Bryn S.Wales
    Default 2.2 direct oil leak
    hi chaps my 54 plate 2.2 direct has an oil leak, oil is all down the offside side of the engine any ideas on where it could be coming from is there any weak points? there seems to be a water housing at the top of the engine and thats clean but everything from there down is covered in oil
    norn iron
    check your oil filter housing, sometimes the rubber seal on the lid needs replaced
    Pen-Y-Bryn S.Wales
    oil filter housing's bone dry m8, the oil is on the other side of the engine by the air filter box
    Pen-Y-Bryn S.Wales
    SCOTLAND
    Think theres a gasket on the timing chain area could be coming from there.
    Pen-Y-Bryn S.Wales
    thanks graeme wouldnt know how i could check would you, i had the airbox out but couldnt see anywhere that the oil could come from without stripping off the top of the engine
    SCOTLAND
    Had a search on the 22 se forum and although its an earlier engine yours may have similar problem.
    http://www.z22se.co.uk/forum/viewtop...engine#p125438
    Edit not too sure how to check i'm afraid i only know becaus we spotted a leak at that side last weekend when ohn robertosn and i had the wheel off then i had my chain replaced yesterday and that seal was knacked
    Pen-Y-Bryn S.Wales
    thanks for that fella, was hopping it would be an easy fix, ill have to do some research to see how difficult it will be to check behind the timing chain and see if i can see anything
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Will be the oil pump/chain cover gasket mate.. common.. Only replace with genuine VX part.. Bit of a pig to strip down etc.
    Pen-Y-Bryn S.Wales
    anyone point me in the right direction to take the cam chain covers off or will an haynes manual have the information
  1. oil leak from vectra c 2.2 direct petrol
    By bigf in forum Engine & Drivetrain
    Last Post: 30th March 2012, 16:05
  2. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  3. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  4. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
  5. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
