Results 1 to 10 of 20
Thread: Slight problem with my headlight washers...suggestions on a postcard
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Slight problem with my headlight washers...suggestions on a postcard
    In February I completed my headlamp washer install with great sucess.
    Then I facelifted the car in March and left the headlamp washers disconected until I bought the facelift headlamp washers.
    So now I have the facelift washer jets fitted, can anyone guess what problem I have now
    The pre-facelift cars don't have fancy headlamp washers and just give 2 squirts of water onto the headlamp. When the facelift jets are connected the 2 squirts are just enough to lift the jets out of the hole but no water comes out Anyone got a clever idea possibly using relays and resistors
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Get af facelift UEC
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Full Member Penfold101's Avatar
    Might be different hoses mate with different internal diameters. I remember ordering the pre-made hose for the facelift and discovering it didn't fit the washer connections on the pre-facelift. There wasn't a pre-made assembly for the it which I assume must have something to do with it. Or the pump is a different part number...
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The pump came from a VXR and the and it's the facelift hose setup thats on it
    I suggest you have a blockage somewhere then make - there's nothing electrical in the system apart from the pump...
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Do the facelifts give two short blasts or one
    I've managed to get the system to work using an air compressor and it will push the jets up and air will come out. When using the water all that will happen is that the jets will pop up twice. I don't think the pump is running long enough for water to come out
    Full Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    mines just 1 long blast , enough to pop up the jets and spray the headlamps for a second
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Did you just blow it right through or did you match the output pressure of the pump?
    Should just be the one squirt mate...
    http://www.youtube.com/watch?v=NC8Wpp-Th80
  1. Headlight washers don't pop out
    By throdo in forum Bodywork & Interior
    Last Post: 27th January 2012, 14:32
  2. headlight washers??
    By vauxhall-john in forum Bodywork & Interior
    Last Post: 4th January 2011, 13:21
  3. headlight washers.
    By Netstar in forum Bodywork & Interior
    Last Post: 2nd March 2009, 16:18
