Results 1 to 3 of 3
Thread: Vec B spongy brake issue
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question Vec B spongy brake issue
    Any brake gurus out there that still log on?
    as well as my signum i have an old veccy B in the fleet and i have just serviced its rear brakes. As i have never changed the brake fluid on the brakes on this car i thought i should do that as well.
    I use a Gunson Easibleed kit so its almost impossible to get it wrong. I have bled the brakes on other cars before and never had an issue. However this veccy b 1.8LS V reg has some horrible spongy brakes.. If i pump the brake pedal when the engine is off the pedal is solid and does not sink to the floor, i understand that this indicates the master cylinder is fine. Its just when driving i get the spongy brake response and i am not happy to be driving it tbh.
    I realize its a veccy B and we do not exactly cover them on this site but we have a lot of good knowledge on here that i need to tap into if possible..
    I have read one possible contender for a fault and that was the ABS pump being at fault, I can pick these up for less then 50quid delivered from the bay or cheaper at a scrappy but have never done one before so practising taking one apart at a scrappy is probably going to be my practise or dry run. What do you think, does the ABS pump sound probable, has anybody had one go and had to replace it or change it themselves?
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    Air trapped in ABS module, use 'vaux-com' to activate abs whilst bleeding them, if that dont cure it it will be the ABS module at fault itself, known fault sympton is the spongy brake pedal.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jun 2009
    South Coast
    hmmm sounds like i am barking up the right tree then... i wonder if my 0pcom will allow me to do that...
  1. foot brake issue
    By 06sri in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2012, 20:07
  2. Lowering Issue....& VRX Brake upgrade...
    By Brian150 in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2012, 23:06
  3. 2.0 Turbo Rear Brake Pad issue
    By a1ant in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 20:54
  4. Brake Issue
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 20:38
  5. vectra cdti 150 brake issue
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2009, 13:18
