Thread: Rear Elec Window / My 3 Year Old Son
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    Default Rear Elec Window / My 3 Year Old Son
    Hello everyone ,
    my son has been messing with the rear passenger side window ..
    up down , up down , up down .
    and it has jammed , but luckily when it was fully up .
    the window motor still makes the exact same noises for up and down ..
    but without moving the glass at all ...
    so i think it's come of the runner / rail ..
    So you know what's coming .....
    please can i ask for advice on removing door cards and what screws / clips to look for ...
    And once the door card is off , i have not got a clue about the window mechanism behind , so i can put the glass back in place ...
    Thank you for any replies / answers ..
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I can't comment on the Vec C but I had the same problem with my drivers door/window on my vec b. It came off the runners and sat on top of them. I contiuned to use the window with some help of a right hand to push it into place. This caused the runners to bend out of shape after a while and I had to replace the lot (less glass)
    Had to drill out the four rivets, remove the motor plus arms and fit the new one from a scrappy then rivet it up again.
    Thats was fairly easy but it took time to line up the glass again. That was very fidderly and took longer than anything else.
    I also had to spray a silicon compound into the window rubbers to allow for smooth movement. It made a big difference mind you. I went around all windows after that applying the spray.
    I would remove the door card and inspect the arms etc, then go from there.
    This how2 will give you an idea on how to remove the rear door cards.
    http://www.vectra-c.com/forum/showthread.php?t=53134
    Hope this helps
    Mar 2011
    @Envy ........................... Thank You
    May 2011
    farnborough
    Default window winders
    hi there i had the same problem with the drivers door window ... went to open the window one morning ... a bang come from the door ... on the window mech there are 4 spot welds which gave way .. poor welding ... another one ordered from ebay and fitted .. took the old one to work drilled out the welds and re welded it now have a spare sitting in shed ...
  1. Problems with astra 5 rear elec window
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2011, 15:30
  2. How 2 Remove Elec Window Switch N/S
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2009, 21:24
