Thread: Local Aircon Fix
    Regular Member JHZ's Avatar
    Feb 2011
    Maidstone, Kent
    Default Local Aircon Fix
    Has anyone had an aircon fix in the locality - namely Maidstone?
    My Vec is far from chilly and I want it to be
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Does it need fixing or just recharging/regassing? If its just a recharge needed then Quikfit can do it.
    Feb 2011
    Maidstone, Kent
    Hopefully just a regas so will try them first.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Fingers crossed it just needs a regas. I had mine regassed and it lasted around 2 weeks. Ended up having a new condensor fitted then regassing again. Might be worth getting it checked for leaks first. I had quite a few in mine.
    Feb 2011
    Maidstone, Kent
    Do you know if kwikfit have the service to check or just regas?
    I am guessing checking for leaks is not a diy job?
    Maidstone, Kent
    If I remember correctly they hook it up to a machine that checks the system for leaks first then regasses it if all is well. Last year it was @£45, don't know how much now though!
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    usually to check for leaks a uv dye is added to the gases so the system basically has to be recharged anyways, a decent place will add the dye and rechare incase there are any leaks even if they arnt any because its lost gas, bring it up to pomphreys
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    where is pomphreys ? and how much do you guys charge mine needs doing too
    Engine : 1.9 CDTi
    They will hold it at a vacuum to check for leaks.
    If it does leak they will first look for the UV dye staining.
    If they cant see any die they shouldn't add gas with dye as its against the law to knowingly leak Aircon gas into the air.
    They should fill the system with Nitrogen and use a 'sniffer' to detect the leaking gas.
    Oh and who ever does it should have a gas handling certificate.
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    its in bapchild mate and i dont know what they charge tbh mate. as for what should be done that is on the ideal world but often to find the problem you have to deviate and be a bit inventive, for example if there is a car with a very hard to find leak youlle put some dye in then let the car go for a week or so then check it when it comes back and nitrogen is the ideal leak detector, when you have some lol. when i regas mine im gonna put dye in anyways to save hastle lol
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Anyone Local
    By Vipes in forum Detailing and Car Care Discussion
    Last Post: 11th March 2012, 20:44
  3. anyone local that can help
    By vectragsi3.2 in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 22nd February 2011, 20:56
  4. anyone local got an op-com please
    By myelite150 in forum Engine & Drivetrain
    Last Post: 17th January 2010, 23:51
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
