Thread: Towbar wiring
    Walsall
    Default Towbar wiring
    Hi folks, quick question.
    I've got a vectra c hatchback on a 57 please, fitted twin electrics from a 08 plate x lease vectra. Not best impressed with the non gen set up, easy enough to wire up but the split charge relay doesn't give out a permanent live, and after towing a caravan both brake light bulbs blew at the same time.
    Moving forward I want to fit genuine 13 pin tow socket with trailer module. The only reason I didn't fit before was the thought of having to pay out more to have Tech 2'd to activate.
    But I've looking into this a bit closer, fuse 13 does have a live to it, put a fuse fuse in and one of the larger pins in the tow socket comes live as does some of the small pins where the module plugs in. So going on this do you think I'll be safe enough to by the kit and should work without booking into the stealers?
    Thanks in advance
    Walsall
    Forgot to as does anyone know the part no of a 13 pin kit with trailer module included. Tile hill Vauxhall quoted £90 but wasnt sure if it came with the module.
    Andy
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Got a part nr. mate? then i can check?
    Oct 2010
    Lincoln
    I've got the VX twin towing electrics fitted to my 56 plate Veccy C and the only problem I have is that the side lights come on with the brake lights
    Apart from that all works fine, fridge etc so maybe yours isn't wired up right? Does it wire into the REC in the boot?
    Wrexham
    I am interested in the part number too.
  1. Towbar wiring need some help please
    By jel0611 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 11:37
  2. Towbar wiring car has pdc
    By waltz in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 20:11
  3. towbar wiring!!
    By kojak01 in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 16:07
  4. towbar wiring
    By dave t in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2007, 12:09
vectra c hatchback towbar electrics
vectra c split charge relay installation
