Thread: Argghhh *********
    Sep 2009
    Glasgow
    Default Argghhh *********
    I knew it wouldn't be long before something else went wrong, as i've posted before getting spanner light on startup that goes opff after 5 min, so t's a glow plug(s), decided to pop off leads and give them a spray of contact cleaner, while doing this i noticed the glow plug relay sitting at an angle, now im sure it wasn't like this before, so a poke with a screw drivwer confirmed that it is moving freely in the engine bay how and why bet it was uncle arnold when they done my stat last month, how does this thing clip back on or is it a screw that holds it in place, just fixed the under guard the other day and now this, when will it end, going to trade her in as soon is i find a suitable car of same size and same or more bhp, you know what even after the trouble ive had with this vec, I have been looking at newer vecs and maybe a vxr.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    I just clips into place on the battery tray.
    I had glow plugs fail not too long ago and just replaced them with some cheapies off ebay, seem to work fine.
    And I'm getting the 'car & spanner' from my alternator Put a non-vx one on due to budget and am regretting it.
    Chin up
    Sep 2009
    Glasgow
    all fixed cleaned contacts on relay as well, still getting spanner light, looks like it's def new plugs i need, is the method of testing the plugs by bridging a wire from terminal plus to tip of plug and getting a spark meaning good plug and no spark bad plug a sound way to test for the dud.
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    That's always worked for me, obviously disconnect wires first.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by nokiaman1978 View Post
    I would get a single contact 12v bulb in a holder with 2 wires,say a side repeater or indicator bulb and holder
    Then take the plugs off the top of the glowplugs
    Put one of the wires from the bulb holder on top of a glow plug and the other wire from the bulb holder on the positive of the battery
    If the bulb lights up,that glowplug works
    If the bulb doesn't light up,the glow plug has gone open circuit and don't work.
    Basically
    Sep 2009
    Glasgow
    i have an led strip that would work ?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    You should do it with a normal 12v bulb as there needs to be a bit of load on it when testing them.
    Sep 2009
    Glasgow
    no probs mate thanks for the info
