Thread: Fabric Seats - Water marks (not Vectra)
    Regular Member Led's Avatar
    Kings Langley
    Unhappy Fabric Seats - Water marks (not Vectra)
    Starting to pull my hair out my wife's Mini Cooper has fabric seats and the car was 'valeted' before we brought it.
    Unfortunately the driver's seat has some water marks on the fabric which are unsightly to say the least.
    Anyone got any ideas how to remove them ?
    Engine : 1.9 CDTi
    Use somthing like a Vax and do a wet clean again.
    Oct 2007
    Shropshire
    Unfortunately this is typical BMW, the fabric they use is very cheap even for fabric seats to make the it look like you get something for the extra money on the upper market ones!
    I reckon a wet vacuum would get rid of that, but if it has been there a long time it may have stained. If so you try this;
    If they do not come out you can strip the seats. I have done this a few times (which is why I know that even some kia seats have better fabric than BMW's!). Strip the fabric off the seat and put it in a pillow case. Sow the pillow case up and they put them in the washing machine. MAKE SURE IT IS A LOW TEMPERATURE! Use lots of stain remover and do it a couple of times.
    Then rebuild the seat. You can get the proper upolstery rings, but I have used good quality cable ties loads of times and they certainly last. My seats have done about 40k on cable ties!
    If they are still stained you need to dye them.
    Regular Member djr69uk's Avatar
    Midlands
    carplan do some upholstery cleaner. halfords or asda even. it is a foam spray and it comes with an aggitating brush end on the canister. worked a treat on some stains in the veccy. spray on... aggitate... leave for a few secs and then wipe off with a clean cloth. might help?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    get it valeted and the trick is to lay towels down after its been done and apply a slight pressure to the whole of the seat base ei: carrier bags full of sand and that mops the rest of the stain up.
    hth
    al.
    Woodbridge
    Quote Originally Posted by Al 22 dti View Post
    Would have to agree, If I was gonna have a fumble in the car, I would put towels down
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by Led View Post
    who valeted that? stevey wonder?
    al.
    Kings Langley
    Not sure who valeted it - it could have been David Blunkett !!
    I'll give the foam/towel trick a go in a week or two and will report back.
    Thanks for the pointers
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    That looks like someone has spot cleaned the bits where the marks are, dont think they are water marks more like marks from some kind of cleaner. Buy some AG upholstery cleaner and with the use of even just a Vax you should get them out no problem.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    the water marks are called Browning its the areas that have become over wet or have had something on them to stop them drying at the same rate as the rest. advice would be scrub and clean whole seat again using a good extraction system to make sure you remove all the water.
    Im a carpet and upholstery cleaner
  1. Boot full of water, footwells, seats wet
    By Ann in forum Bodywork & Interior
    Last Post: 29th December 2012, 23:02
  2. Water marks/milky spots
    By the-wizard in forum Detailing and Car Care Discussion
    Last Post: 26th April 2012, 18:14
  3. CDTi 120 timing marks & water pump
    By R33Leroy in forum Engine & Drivetrain
    Last Post: 6th April 2012, 22:25
  4. water marks after waxing
    By Big Knox in forum Detailing and Car Care Discussion
    Last Post: 28th June 2009, 21:49
  5. Chrome - 'water' marks?
    By Adam in forum Detailing and Car Care Discussion
    Last Post: 20th July 2007, 21:59
