Results 1 to 10 of 19
Thread: what torx socket do i need ?
    May 2011
    shildon
    Default what torx socket do i need ?
    hi all, i have just gone to change the discs and pads on my father in laws 2002 1.8 vectra c, but straight away i got stuck because i didnt have the correct tool to take the slide pins out.
    the write ups i have read for this job have stated that it was a allen key fitment but on this car it is not, they are female 6 pointed.
    does anyone know which male tool i need to fit them ?
    Regular Member Jezzy's Avatar
    S.E
    7mm allen key for the slide pins. You'll need an E20 Torx socket to remove the front caliper carriers, an E18 for the rear ones.
    Pull off the round, black plastic covers to reveal the slot where the allen key goes.
    May 2011
    shildon
    7mm allen key does not fit.
    it is some sort of torx bolt.
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Quote Originally Posted by white.akita View Post
    when i had my caliper of i didnt need anything i was able to pull it of with my hands,
    Regular Member RobW's Avatar
    Tain - Easter Ross
    The bolts you are looking at will be the ones holding the caliper together! I made this mistake too, ended up pulling the caliper apart!!
    There will be 2 black plastic covers over the slides, pop them off and the 7mm will fit in there.
    S.E
    You're looking at the wrong bolts fella. Maybe you'd be better off leaving it to pros, like KwikFit....
    May 2011
    shildon
    yep i popped the two plastic covers off and in there is the 6 pointed torx screws.
    May 2011
    shildon
    do the bolts that hold the calipers together have plastic/rubber covers on them also ?
    none of the pictures in any of the write ups look like the calipers on his 2002 1.8 vectra c.
    i have changed brakes before on my own audi's and bmw's without any problems.
    i recently changed front discs and pads on my 330d m-sport without problem.
    Mar 2011
    Donegal
    take a picture of behind the calipers, on my 2.2 there was 3 torx head bolts holding the caliper in place, i removed them then knocked the caliper from the brake disc and the slide pin part pulled of by hand,
    thats just my experience, and my 3 bolts where really really really tight, id advise half inch braker bar, as i busted my have inch ratchet and my nose.
    S.E
    Here's a picture of ATE calipers from a Vectra, just like you have. The 7mm allen key goes in the hole I've circled in red. The Torx bolts go where I've put blue X's:
  1. Torx screws!
    By larrysSRI in forum Bodywork & Interior
    Last Post: 19th April 2012, 15:57
  2. which torx
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 28th September 2011, 01:56
  3. cheap torx set.
    By jimmyred in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 21:54
  4. torx sockets
    By slugo in forum Engine & Drivetrain
    Last Post: 19th January 2011, 17:25
  5. Torx Screwdrivers?
    By Matt21385 in forum General Chat
    Last Post: 26th April 2006, 15:54
what number torx socket for brake caliper
torx tools for vectra c
