Results 1 to 3 of 3
Thread: 1.9 cdti vectra 2008 fly wheel
    May 2011
    leigh
    Default 1.9 cdti vectra 2008 fly wheel
    Hi all
    I have been told that the fly wheel could be the reason my vectra has starting trouble? The diagnostic comes back with a crankshaft sensor but having replaced that I can rule that one out, have cleaned the egr valve, swapped the air flow meter and reconneded an air pipe that had come disconnected at the bottom of the air box ....... Any ideas????
    Engine : 1.9 CDTi
    Check the bottom pully isnt moving on the woodruf key
    Dec 2010
    wirral
    what is the fault? i have a 120cdti on a 56 plate.
    sometimes it takes 10 seconds of cranking before it will start.
    other times it fires up with in a second.
    also an eml lamp stays on but no codes.
  1. My 2008 Vectra SRi 1.9 CDTi 150 :)
    By Ross-SRi in forum Quick Photo Album
    Last Post: 21st November 2010, 09:38
  2. 2008 CDTi vectra. Help needed please!!!
    By 123rado in forum Introduce yourself.
    Last Post: 13th June 2010, 10:51
  3. Vectra c cdti 2008 cooling fan
    By castrader in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:53
  4. 2008 Vectra Elite Cdti
    By twinsetal in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2009, 01:05
  5. 2008 '08 Vectra SRi 3.0 V6 cdti
    By Neil71 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 31st January 2009, 20:33
