Thread: Vectra C aerial help
    Sep 2010
    Cambridge
    Default Vectra C aerial help
    Aerial Info. Have a Vectra c 2008. Have problem with aerial, (the cable has snapped somewhere between the radio and aerial). Can anyone tell me if the signal is amplified at some stage or is a straight single aerial cable connection. I propose to run a new cable from the radio to the new aerial I will buy and would appreciate anyone's advice or previous knowledge. Thanks - George
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    would assume its a straight through cable from the radio if your using a standard setup, but will stand corrected if i'm wrong.
    Liverpool
    I beleve that the signal is amplified via the headunit itself (standard VX) as i had to buy a separate amplfier for my aftermarket one, so you should be able to just run some new cabling through
    Sep 2010
    Cambridge
    Thanks for the replies. Have already ran the cable thro' but will take on board the info from paul sri150 about adding a seperate amplifier. - George
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    If you have a Sharkfin type aerial then sometimes the amp is in the base of the antenna, with the exception of that - what Paul said,lol.
  1. vectra c roof aerial change +cd30 to cdc40 help!!!
    By matrix1979 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd August 2011, 22:25
  2. Anyone Know Where To Get A Vectra DAB Aerial???
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2009, 14:00
  3. Vectra DAB Aerial Wanted
    Last Post: 6th December 2009, 12:55
vectra c aerial problems
vectra 2009 how to connect dab aerial
