Results 1 to 10 of 13
Thread: Air-con help needed
    Regular Member 92nc30's Avatar
    May 2011
    Ipswich
    Default Air-con help needed
    Hi,
    I have a vectra C 1.9cdti (150hp) Elite Estate and I had the dreaded blocked drain and alot of water flooded the footwell, after sorting that out and checking everything worked ok, I was happy. But having stuck the air-con onfor the warm weather,my air-con hasn't been cold at all. Thinking that I hadn't used the air-con much I got it regassed and it has made no difference at all. The garage told me the compressor would need replacing. Not trusting them I did a check over things and found no fuses gone, relay ok and but i did find the compressor clutch not engaging. I am going to try to stick 12v direct to it tomorrow afternoon but need help. There are 2 wires going into i believe, which one will require 12v+ slapped on it?. Also is there other things to check? ie low pressure sensor and where it is would help I've had a good look but cant see anything like one.
    Any help would be gratefully recieved as I refuse to pay out for something that might not even be at fault.
    Also, I have just bought a Haynes manual and the wiring diagrams are rubbish Is thare anywhere I can get a decent wiring diagram for the aircon system?
    Thanks in advance
    Matt
    May 2011
    Ipswich
    Right I had a good climb under the car and found 12v going to the clutch, pulley turns free enough but I did find the clutch coil has no resistance. Now reading up on the coil there is a thermal fuse in it. Is this an easy job to do and can it be done on the car, I dont fancy taking the compressor of as I just had it filled.
    Thanks for any help
    Glasgow
    The compressor wont come on if there isnt enough gas pressure. Its a safety thing so it cant operate with no gas. If theres no gas it must be leaking, there must be a leak somewhere either due to damage from road debri or due to lack of use.
    It needs a proper leak test done mate.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    I thought my air con was broken but fiddlein round I found I had turned it off in the computer thingy felt right a total plank!
    May 2011
    Ipswich
    byebyeitsagsi - I've just had the system regassed and they found no leaks, I hadn't used it for a while and it lost the gas. The compessor is being asked to run as I have checked the voltage down to it and also stuck 12v supply direct to the unit with the car running and still no joy.
    TimTay - the numptys at the garge hadn't turned on the aircon - still had it in eco mode when i got it and h#was hopefull that would be the problem but again no joy.
    Its defo the electric clutch gone wrong . I need to know if i can chane just that or have to do the whole compressor
    Nov 2010
    BRECHIN
    Quote Originally Posted by 92nc30 View Post
    So that's what the Eco means! Pmsl
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    John.Robertson was having much the same issue, but his clutch burned out. You can get a new clutch for it but wait for it, hope your sitting down, £400 from vx for one, lol.
    Quote Originally Posted by TimTay View Post
    RTFM time perhaps?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by byebyeitsagsi View Post
    If the air con clutch has burned out then the clutch won't engage
    I have a replacement air con compressor sitting here for mine ass it was cheaper to buy a whole new compressor than to just buy the clutch.
    The clutch unit should come off of the compressor easy enough but I've not hasd a propper chance to have a look.
    Although I don't have climate control, like you I have 12v at the compressor so it is trying to engage but the clutch isn't responding
    May 2011
    Ipswich
    Update time. I got compressor from eBay and checked the clutch was ok. I took the clutch off which was easy on a bench. Today I managed to change the clutch, it was easy but anyone wanting to do this will need some plong 90 degree circlip pliers to get the circlip that retains the electro-magnetic coil on the compressor.
    Now I have very cold air con again and a sore knuckles from the lack of space in the engine bay.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
