Thread: Error code P1901 - DPF Blocked
    Regular Member rockonoli1's Avatar
    Telford
    Default Error code P1901 - DPF Blocked
    Had the car with the spanner light come on, c/o a diag check using my snap-on tester and got the error code P1901 when looking through the code/tip section on the tester the corrective action to take is apparently a ecu update and service regen on DPF, how do I know if my car is due the update without getting raped by VX. I also took the car the length of the M54 approx 50 twice in 3/4 gear high revs to try and clear the DPF but no good, I know they can be a b***h to clear has taken me 3 hours to do a new shape Fabia at work the other week. All to save the planet what about my pocket with the amount of extra fuel it uses when trying to clear!!!
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    just remap and gut your dpf simples
    Telford
    To expensive at moment gonna have another little sprog running around in the next couple of weeks so need a semi permanent fix ( once the wife has had the baby, I'll try and get a remap)
    Sep 2010
    in a box
    well its an all in job foe £300 and a new dpf is 300 on its own running up and down moterway cant be cheap.............take it off and jet wash it out someone done it on here and worked ok up to you really or take it to vx and make them do regen for you £60 that
    Telford
    I did see the thread with the jet wash and thought about giving it a go but..... I don't know jut probably would work for me Would VX charge for the ECU update as I know we don't at work, just like Microsoft don't for computer updates ???
    Sep 2010
    in a box
    dono and the update is just a regen every 1000miles insteed of say 3000 miles.but yer id say vx will say its x amount as nothing free from them or drill a hole 10/12mm in your dpf all way from one end to other lol
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. error code 10 1 3 10
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 27th June 2011, 16:31
  3. error code
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 21:43
  4. Error code help
    By Cat_J in forum Vectra C / Signum Troubleshooting
    Last Post: 18th January 2010, 17:48
vectra c eroare p1901
