Results 1 to 3 of 3
Thread: 2004 Saab 93 2.2 TiD Fault P0244 wastegate
    May 2011
    Default 2004 Saab 93 2.2 TiD Fault P0244 wastegate
    First time poster Hi all
    I know this isnt a vectra c but its the same GM engine so I thought someone may be able to help..
    Having a issue with my 2004 Saab 93 2.2 TiD, Was driving and became very sluggish. and then when i went to around 3000 revs EML came on. Got the code read and it came up as P0244 Turbocharger Wastegate Solenoid A Range/Performance. Tried looking at all vacuum/air pipes, replaced ones which looked like they needed replacing.
    Still coming as same fault. Also cleaned egr, was coked up with soot but now clear. Cleaned intake manifold out and also have replaced the solenoid.Still getting same issue.
    I can clear the code and drive around town but as soon as I try to put my foot down a little it just pops back on and it drops back. Usually after 60mph over 3000 revs.
    Vacuum pipes all checked for leaks.
    Intercooler pipes checked for leaks.
    Intercooler checked for leaks.
    wastegate actuator seems to be moving freely.
    I get a vacuum when pipes are taken off but when checked with a proper saab tech 2 i get boost pressure low..
    Anyone got any suggestions?
    Anyone had this issue before?
    Thank you in advance
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    hi
    i had saab 93 2.2TiD se
    i also had problem and i came out actually : crack sensor which is about £15 and if you have "know how" you can fitted your self but would sagest to reset ecu
    West
    Try cleaning the boost sensor & also check the vac pumps are actually working
  1. P0244 error and turbo cutting out
    By Ian-Highlander in forum Engine & Drivetrain
    Last Post: 27th August 2012, 11:41
  2. p0100 Fault 2.2DTI 2004
    By 1TAYLOR1 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 22:05
  3. tubrocharger wastegate
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 18th March 2012, 10:17
  4. Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    By danBoy in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:45
  5. 2004 veccy fault code reader
    By iasha in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 19:25
p0244 saab
2.2tid fault code PO243-09
saab vector 2.2 p0244
saab p0244
saab 2 2 tid p0244 code
saab code p0244
p0244 saab 93
saab 9-3 2.2 tid p0244
saab 2.2 sluggish p0244
saab 2 2 tid p0244
saab 93 error code po244
vectra 2.2dti code p0244
p0244 saab 2.2
