Results 1 to 2 of 2
Thread: Suspension knocking? Will Vec c suspension fit a Siggy?
    Apr 2011
    Cornwall
    Default Suspension knocking? Will Vec c suspension fit a Siggy?
    Ive recently noticed the odd knock coming from the front nearside of my 2.2 petrol Siggy on harsh right cornering so suspecting there may be a problem with my suspension? Any ideas what this could be? It only recently went thru an MOT too!
    I quite fancied changing the suspension anyway to lower it but was wondering if I could buy Vectra c suspension? Would this fit? Saw a full set of supersprint shocks and springs on fleebay the other day that would fit any petrol vectra but didnt buy them as supersprints website showeda different product code for my Siggy.
    Any knowledge would be gratefully received! What has everyone else done with their Siggys?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi shane most common damper spring update is the bilsten B4 dampers combined with eibach springs or supersport springs as in my case this will give you around 30-35 mm drop on your ride height others have just changed there springs to sri springs which will give you a 15mm drop there,s lots of options right upto fitting coilovers , i am sure others will be along to tell you about there setup,s
    Common fault with signum,s is ware in the drop links along with the ARB bushes these will also give you your knocking noise and are reasonably cheap to fix compared to changing your suspension setup
  1. suspension knocking again
    By wirrallad in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2012, 18:30
  2. Knocking suspension
    By cosjon in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 14:55
  3. knocking on o/s suspension
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 15:18
  4. Knocking suspension
    By marko21 in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2008, 15:24
  5. Suspension Knocking
    By D-S-Dave in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2007, 01:31
