Thread: Spanner light - no codes
    May 2011
    London
    Default Spanner light - no codes
    Hi
    Car: 2005 Vectra 1.9 CDTI 150 SXI
    Miles: 105K
    Issue: light on dash (spanner over car)
    I have scanned the car with my diagnostic lead and there are no codes.
    One other thing I have noticed is that the car is slightly slow to start up, but drives perfectly fine.
    Any advice gladly recieved
    Mar 2011
    stirling
    hi i had the same problem with mine it would onluy show up on tech 2 or a bosh system, also had the slow to start , mine was the woodroof key on the crank pulley, its an easy fix ,i think the garage are charging me around 300 all in, but it made it like new again, just watch mine is a left hand thread and the first garage snaped bolt cos they were turning it wrong way
    May 2011
    London
    sounds complicated
    Mar 2011
    stirling
    its not complicated really just get a good garage to replace the bottom crank pulley but make sure they have the proper timing tools, if not it all looks good but is still 2 teeth out, when its plugged in it will come up with cam sensor fault, i changed mine 2 times before they found out it was the crank pulley woodruff key
    11 Post(s)
    Quote Originally Posted by dickybow View Post
    Can you confirm this as the fault light has a spanner going vertically through the car, not a spanner over the car symbol.
    May 2011
    London
    Big spanner standing up straight in front a symbol of the car. Goes out after 3 mins of driving.
    Thanks for all your help
    11 Post(s)
    One or more glowplugs are faulty would be my guess.
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    +1 on that dave
    May 2011
    London
    Interesting because in the morning the glowplug light extinguishes after a second like any other diesel and during the day it barely blinks on ignition - to me thats a good sign !?
    On my old Merc C220 CDI, the glowplug light stayed on for a good 5 minutes to signify they needed changing.
    Cheers!
    West
    deffo glow plugs... try turning the key on and off a few times to bring the plugs on for longer before starting... until you get round to changing the plugs
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 0
    Last Post: 26th August 2012, 03:15
  3. Spanner light no codes
    By DHobbs in forum Engine & Drivetrain
    Last Post: 5th April 2012, 12:05
  4. No codes being displayed - Spanner light
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2011, 22:41
  5. Spanner light/limp home/fault codes?
    By Factory Pilot in forum Engine & Drivetrain
    Last Post: 17th June 2009, 09:09
