Thread: poor cold starting CDTi 120
    lincolnshire
    confused poor cold starting CDTi 120
    last 3 weeks or so the XP has been ropey on first cold starts i've changed the glow plugs cos if i heated them up 3-4 times it struck straight up ! it is a little better with the new plugs in but on a 56 plate i'd expect it to start first go everytime ! it runs spot on and hot starts are as they should be so any ideas people ??
    lincolnshire
    late evening BUMP ! does no one know why these 120's dont start from cold then ? went through christ knows how many threads last night and beyond a glowplug swap there's nothing else as a suggested cure for this issue ! well i've been told there known for the fuel filter housing cracking ! ?:?? anyone else heard this ???
    Regular Member vanquis1979's Avatar
    gainsborough
    is the old girl giving you bother bembo if it helps mine starts on the button lol .... mind you i passed it today and god dam i should of kept it looks awesome
    Regular Member Mopar Man's Avatar
    herts
    Yes when an animal has unscrewed the top.
    I used to have a 120 and that never started very well ether. Spoke to a mate at vauxhalls at the time and he said, they had a few in like this and all had a slightly bent con rod. Water damage at some point.
    It will run and start fine when warm. You can check this by removing the glow plugs, put a thin rod down the bore at TDC and mark and measure.
    lincolnshire
    i doubt very much its a con rod , been starting fine up until the last couple of weeks or so ! i've known other diesels suffer with that though !
    lincolnshire
    Quote Originally Posted by vanquis1979 View Post
    no jode ,not really , jus cold starting can be a pig of late ! other than that shes been mega ! still cant believe a car can do so much so well and the space in the back is hugemongus !
    lincolnshire
    saturday night BUMP ! surely with all these CDTi's outthere some one has a cure for poor cold starting thats not a glow plug swap ???
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I've got similar problems to you bud
    If I turn the key to position 2 (ignition) two or three times prior to starting the car it starts fine.
    Had all the glowplugs changed over in November so It can't be them.......
    Heard people mention about changing "Leak-off pipes" and also possibly the "Injector Seals" but have yet to get round to trying them out. Will be cleaning the throttle body out when I get a chance as that'll be another thing less to try lol
    As with you once the car is running it runs and starts well.
    Priorities for me first though are to replace the droplinks (have just ordered some uprated saab ones), ARB's (front and rear) and rear upper control arms, as since lower the car it seems to have started to rattle itself to death
    Hope you find a solution and get it sorted
    Damo
    lincolnshire
    ok Damo , if i find a solution before you then i'll post it up ! looked at my leakoffs y.day and all look fine , i reckon if they were goosed it wouldn't start when warm either though
    herts
    Worth checking you are getting voltage to the glow plugs?
  1. Poor starting.................but not from cold
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2013, 07:32
  2. Poor Starting CDTI 150 Auto
    By 1075 in forum Engine & Drivetrain
    Last Post: 26th January 2013, 18:06
  3. 56 plate cdti 120 cold and poor starting
    By bigbadcat in forum Engine & Drivetrain
    Last Post: 5th June 2012, 17:28
  4. Poor starting 1.9 CDTI 120 Hot & Cold
    By lehapau in forum Engine & Drivetrain
    Last Post: 4th October 2011, 20:06
  5. 03 vectra dti poor starting when cold
    By jono m in forum Engine & Drivetrain
    Last Post: 11th November 2010, 14:16
vectra c tdci 120 starts poor and could of smoke
vectra cdti poor cold start
vectra 1.9 cdti poor cold starting
