Results 1 to 10 of 23
Thread: advise on spraying
    Regular Member Garfo's Avatar
    plymouth,devon
    Question advise on spraying
    hi guys and girls
    i want to spray my front grill
    so any 1 got a step by step guide of how they done theres
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    i too am interested in this
    Oct 2009
    me also... matt black I think
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Anyone?
    Regular Member connery-sri's Avatar
    Basildon, Essex
    I have done a few bits of spraying myself. Not that great though. Have a search thru the site, sure there have been threads in the past about spraying.
    HTH
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    The only advice i can give you is to take your time with the prep. The more time on prep, i.e. sanding,priming,masking etc, the better the end result will be. And short bursts on the gun/rattler prevents runs.Build up the layers gradually,fine grade sanding every few layers to keep it even, don't rush and the results will be v.impressive.
    Regular Member Jezzy's Avatar
    S.E
    1) Paint doesn't stick to smooth surfaces, so you need to "key" it - sand it with a fine grade of wet'n'dry paper, to give it a slightly rough surface.
    2) Clean the surface with paint wipes (from Halfords) or similar.
    3) Wipe with a tack cloth (sticky cloth)
    4) Apply primer. As with all can sprays, apply thin coats; don't be tempted to apply enough in one go to completely hide the colour you're spraying on top of. Leave to dry for half an hour if in warm environment, more if it's cooler.
    5) After each coat of primer, use a fine grade of wetted wet'n'dry to "flat" the surface - necessary because sprayed paint doesn't settle evenly and as you build up more coats, the uneveness will also build up.
    6) Wipe with paint wipes and tack cloth again.
    7) Apply next coat of primer. Repeat above steps until 3 primer coats have been applied, then flatten again and clean.
    8) Apply the colour coat. Leave to dry.
    9) Flatten paint with wetted wet'n'dry.
    10) Wipe with paint wipes and tack cloth again.
    11) Apply next coat of colour.
    12) Repeat above steps - colour coat, flatten with wet'n'dry, wipe with tack cloth etc, apply more colour - until 7 or 8 colour coats have been applied. Stop when you're happy with the colour shade.
    13) After the last coat of colour DON'T use the wet'n'dry paper.
    14) Apply clear lacquer. 3 or 4 coats will be needed, don't flatten the lacquer between coats.
    15) After the last coat of lacquer, let the paint harden for a week or two (this can be on the car, or with the sprayed item removed).
    16) Then "cut" the paint using good quality cutting compund such as Farecla G3 and applied with a power tool, such as a mop attachment fitted to a drill. This will smooth the top surface to compensate for not being able to use the wet'n'dry paper since just before the last colour coat. Polish to shine.
    Job done.
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Cheers jezzy very useful and shall follow that, so how long will it take to get it to the fully lacquered finish? I'm assuming a few days atleast?
    Regular Member Innes's Avatar
    Plymouth
    What Wet N Dry grade do you reccomend?
    S.E
    Quote Originally Posted by Innes View Post
    For flatting the paint coats, 1000 or 1200 should be fine. For initially "keying" the surface that you want to paint, anything from 600 to 1000.
  1. Spraying
    By Yenyaw in forum South East (ARO jaqubek)
    Last Post: 1st August 2012, 14:43
  2. how much for spraying?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 13:16
  3. spraying
    By WKD-mcc in forum Styling
    Last Post: 17th April 2009, 15:48
  4. need spraying
    By wanna veccy in forum General Chat
    Last Post: 30th April 2008, 17:05
  5. spraying
    By simon5800 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2007, 22:01
