Thread: Parrot Mki9100 & Center speaker
    Apr 2011
    Northamptonshire
    Question Parrot Mki9100 & Center speaker
    I had an Mki9100 installed today into my CD70 Navi, all works fine except for the Center speaker not muting. The installer seemed stumped by this, it doesn't seem right to me, is there a fix?
    Ian
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Unplug it for the time being but make sure you dont drop the screws into the dash when you take it out. Not sure why it does not mute. If the installer has done the job correctly and attached the mute wire then it should be fine. We have the CD70 with MKi9200 in the Signum and it seems fine. Will check tomorrow if the speaker has been disconnected.
    Apr 2011
    Northamptonshire
    Quote Originally Posted by merikiito View Post
    Thanks, I look forward to seeing your findings.
    Aug 2010
    Stoke on Trent
    I have the CD70 Navi with Parrot CK3100 and my centre speaker mutes so no idea why yours wouldn't..??
    Apr 2011
    Northamptonshire
    Quote Originally Posted by jimbojetset View Post
    Interesting, the other speakers mute perfectly, the installer runs a Vectra C himself but his doesn't have a center speaker. There was something installed previously but no idea what it was, just a mark on the dash.
    Ian
    WGAF#5
    he hasnt selected the correct mute as when you use the system it SHOULD show aux on the screen when used
    Redditch
    I think its number 9 and a pink lead from memory but there is a post on here if you do a search
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    i had something similar when I did mine. I had to change a connector from bullet to spade, or vice-versa, and a bit of trial and error.
    Some notes here: http://www.vectra-c.com/forum/showth...t=10126&page=3
    and here: http://www.vectra-c.com/forum/showthread.php?t=125719
    Apr 2011
    Northamptonshire
    Thanks all, I have emailed the supplier and asked when he an send an installer out to rectify this issue.
    Ian
  1. Parrot MKi9100 are they easy to fit ?
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2011, 12:00
  2. Parrot MKi9100
    By Homer in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 18:10
  3. PARROT MKi9100 - NO POWER HELP
    By typecastboy in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2010, 09:41
  4. Parrot Mki9100
    By johnynoi in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2009, 21:44
parrot vectra center speaker
How do i mute centre speaker in my 2008 vauxhall
