Results 1 to 10 of 17
Thread: threaded hub and bolts!!!
    Jul 2010
    lancs
    Angry threaded hub and bolts!!!
    hi,
    was putting my wheel back on at the rear drivers side. and one of the bolts was threaded and even with a new bolt it won't screw into the wheel hub.
    So couple of questions?
    1). Is there a minmum number of screws that need to be in to drive it?
    2). Can the hole be re-threaded?
    3). How easy is it to swap the wheel hub???
    Regular Member GCM's Avatar
    May 2007
    Coventry
    Hi, I had a cross threaded wheel bolt in one of my hubs after having my tyres changed, I brought an M12 x 1.5 tap and carefully cleaned the thread out on all five holes and fitted new bolts with no problem.
    If the bolt still torques up ok to the recommended 110 Nm I think you should be ok, but if it strips the thread completely on the damaged one, you will either need to replace the hub or have a helicoil thread repair undertaken.
    You can buy a helicoil repair kit of e-bay for around £16, but personally I would replace the hub.
    Hope this helps.
    Jul 2010
    lancs
    just bought a re-threading tool but still can't seem to get it to re-thread.
    what is involved in changing a rear wheel hub on a vectra c?
    Looked in the Haynes manual and it talks about needing a coil spring compressor. Is this right??
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Quote Originally Posted by ickleric View Post
    A re-threading tool....do you mean a tap or helicoil kit?..... did you get the right size and check its not left handed. You should have no problems running a tap through the old thread.
    Jul 2010
    lancs
    a tap. can't seem to get it passed half way. when you say left handed. can it only be turned one way???
    Chelmsford
    Coil spring compressors can be had for a few quid on eBay.
    Pretty easy job to do rear hubs, can't imagine you'd have too many problems.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as rob says you should be able to retap thread ok,no compressor needed, calliper of 4 nuts on rear of hub and it's off,£80 to £180 depending where you purchase it from.
    Feb 2011
    london
    tap should be right hand....turn CW to wind in then reverse CCW to undo
    what does it read on your tap..your tap should be M12 X 1.5..... if it has LH (left hand) on it then you have wrong tap.
    Jul 2010
    lancs
    i was using a 1.75. the 1.5 just goes straight through.
    Feb 2011
    london
    if its M12 x 1.5 going straight through then you have completely stripped the thread...are you sure you was not using M10 x 1.5....changing the pitch to 1.75 the bolt wont fit
  1. threaded glow plugs help
    By muddydude in forum Engine & Drivetrain
    Last Post: 4th October 2012, 18:36
  2. For Sale: 4 x10mm spacers, spigots, longer bolts and locking bolts
    By 6009tristanb in forum Parts for sale
    Last Post: 25th September 2011, 20:02
  3. glowplugs threaded
    By alphabravo in forum Engine & Drivetrain
    Last Post: 27th February 2011, 06:54
  4. cross threaded glowplug
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 20th June 2009, 13:58
how to re tap vectra c wheel hub
