Thread: 3.0 v6 cdti timing belt
    Default 3.0 v6 cdti timing belt
    just changed the timing belt on the siggy
    wasnt bad to do until trying to get the belt on and turned the tensioner to give more play on the belt and the locating pin on the tensioner sheared off
    lucky i still had the old tensioner so put it all back together and flinched as i turned the key and ........it fired up straight away
    looks like will have to get yet another tensioner and change that part again , will be able to use the old belt as its brand new
    just got the aux belt and tensioner to do now
    took some pics so will attempt to write a how 2 later
    Full Member Big Sig's Avatar
    Did you check the valve clearances too? I have a funny feeling they are due at a similar milage
    jnot yet will get round to that later in the week or next week
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Valve clearance check will take you all day. And you'll have to do it twice. Once to check the clearance and then to replace the shims to adjust everything. Good luck mate
  1. where to get 19 cdti 150 timing belt kit?
    By ronnie63 in forum The 'Off Topic' room
    Last Post: 25th August 2012, 17:24
  2. 150 cdti timing belt again
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 09:33
  3. Timing belt on 1.9 cdti 150?
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 10:35
  4. cdti 150 timing belt kit, where's best to get it from?
    By veralum in forum Engine & Drivetrain
    Last Post: 19th January 2010, 18:32
  5. Timing Belt CDTi 120
    By ROB WOODHOUSE in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2006, 23:25
when should i change timing belt on vectra c cdti v6
vectra v6 cdti engine belt
