Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Over filled the oil...
    Regular Member bigdave1701's Avatar
    York
    Default Over filled the oil...
    I topped the oil up on my 2.2 dti last night but I wasn't really paying attention to what I was doing as my son was screaming round the front garden. I've driven to work today and left the engine 5 mins then checked the level and its about an inch and a half over the max mark so I'm guessing I've over filled it by about a liter. Is this going to cause me a problem? I don't know if it makes a difference but in the past 6 months the car's chewed its way through 4-5ltrs of oil!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If diesels are overfilled with oil they can actually start to run on it via the oil breathers in the intake system.
    Just watch for the surging and the reluctance of the engine to switch off when you turn off the ignition.
    Gazza4
    That's quite a bit of an overfill and may well cause you problems - blowing seals etc.
    I'd drain the excess out rather than just let it burn through it normally. If you can find a friendly garage/mechanic who has one of those oil sucker thingys (removes oil through the filler) it'll save you dropping it from the sump.
    York
    When I started it this morning there was ALOT of smoke for a couple of miles and the engine revved a little when I came off the accelerator but since then has been fine. You've got me worried about driving it home now.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by bigdave1701 View Post
    The only real way is as Duncan says.
    Gazza4
    York
    I don't know any friendly garages.... Looks like I'm donning the overalls tonight. Biggest PITA is that my jack and axle stands are at the in-laws 70 miles away so I'll have to rely on the spare wheel jack to hold the car while I open the sump!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    That's quite a big overfill.
    York
    I know
    Sep 2009
    Glasgow
    you can do it the easy way yourself get some clear rubber hose from halfords and a push down lid like on soap dispensers, put the hose onto the bottom of the dispernser, put the tube down the dip stick hole and squirt the oil into a container.
    Dont get under the car when its only held up by the standard jack!
  1. Just filled up How Much?!!!
    By the_wave_rider in forum General Motoring Chat
    Last Post: 19th March 2012, 13:17
  2. should have filled up!
    By TimTay in forum General Chat
    Last Post: 27th July 2011, 14:17
  3. Gear Oil over filled....!
    By olid2002 in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 12:25
  4. Filled my car up today
    By Steevo in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2009, 10:20
  5. Just Filled Up
    Last Post: 10th November 2008, 20:34
