Thread: Issues with CDTI 1.9 SRi 150
    May 2011
    Nottingham
    Angry Issues with CDTI 1.9 SRi 150
    Im having real issues with my Vectra CDTI 1.9 SRi 150 at the moment!!, the emissions warning light has been on, which was to do with the EGR valve, cleaned it and its still coming up as an error, so am having to fork out for a new one!!. But since i cleaned this and the boost sensor my turbo has gone mental!!. It used to kick in at 1700, now its more like 2500....like driving a bus at the moment!!!
    Anyone got any suggestions?!!
    Aug 2010
    Stoke on Trent
    Check your boost sensor plug is connected correctly then unplug the egr valve and see if there's any difference... also get the codes read and post them here... also look at your swirl bar... is it connected..??
    West
    In addition to the above check the vac pipes for any splits
    May 2011
    Nottingham
    Hi Fellas,
    Thanks for the tips, soz been away and not had chance to reply. The code i keep getting is P400 of my mates code reader. Changed the valve, but im still having issues with the Turbo!!. I can hear it whistle at 1700, the car does accelerate well but im not getting the kick into my seat like i used to, is this normal?. Should it be this smooth, its weird but i miss waiting for my power and then enjoying the car take off!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Check for boost leaks, split pipes etc. there is a couple at the front right of the engine that split (usually 6mm black ones) plus get someone to rev the engine while you check for leaks. The main pipe at the right hand side of the engine should swell up under pressure, if it doesnt it might be split or one of tthe other pipes are. Also check your intercooler for leaks
    May 2011
    Nottingham
    Checked the Vacuum pipes and they are ok, will check the others, thanks!
  1. 1.9 cdti 150 eml & EGR & DPF issues
    By carvaletingpro in forum Diesel Engine related
    Last Post: 24th August 2012, 08:16
  2. 1.9 CDTI 150 - Issues
    By me9141 in forum Engine & Drivetrain
    Last Post: 27th April 2012, 17:56
  3. cdti 150 mpg issues
    By Kcs in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2011, 23:44
  4. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
