Thread: sticky PAD (Parrot Attachment Device) help needed
    Regular Member dlp's Avatar
    Mar 2011
    Cottesmore, Rutland
    Default sticky PAD (Parrot Attachment Device) help needed
    Right so when I bought my car the bluetooth kit was hanging off.
    No problem, bought some 'permanent' stick foam pads - voila. Problem solved.
    Except that it's doing it again now after 5 months in place (actually it's been like it for about a month or so).
    Anyone got a suggestion of a more permanent way of affixing my Parrot kit to the dashboard without drilling etc?
    Regular Member farley2708's Avatar
    antrim n.ireland
    what about the sticky pads they use to attach number plates with? they are what are holding on my number plates
    pm me with your address if you want me send you some
    Redditch
    I used the number plates ones and it hasn't moved since
    Mar 2011
    Cottesmore, Rutland
    Thanks for the suggestions: @Farley I'll send you a PM now.
    Thanks again!
    WGAF#5
    also make sure that the surface is squeaky clean - make sure its wiped with a surgical/ alcohol based wipe that way the pad will adhere better to start with
    Regular Member Jezzy's Avatar
    S.E
    Those alcohol wipes are freakin tasty...
  1. Vec C Parrot Help Needed
    By vect001 in forum Electrical & ICE (including SatNav)
    Last Post: 29th October 2012, 13:37
  2. Parrot Mki9200 Help Needed
    By scifi76 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2011, 13:02
  3. Advice needed with Parrot MKI9200
    By trendwarfare in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2010, 15:33
  4. Parrot Ck3100 Kit 2007 Help Needed
    By mushy2007 in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2007, 17:41
  5. Sticky situation ~ advice needed
    By Deadman in forum General Chat
    Last Post: 10th May 2007, 22:49
