Thread: Head unit / Compatability etc
    New Member SlimboyFat's Avatar
    May 2011
    South Yorkshire
    Default Head unit / Compatability etc
    Vectra 2.0 DTI LS. 2004 so not the facelift. Clock is the small 2 line display.
    Hello,
    Planning on replacing the standard head unit (CDR 2005) as its a tad temperamental playing CDs.
    I have a JVC KD-R401 that I removed from a previous car that would do the job nicely.
    1st question is can this head unit be used with the steering wheel controls? Is there a socket on the head unit I should check for to confirm this?
    The 2nd part of this post is that a work mate had a Vectra Facelift (believe it was a 2009) "Full Cambus" which he replaced the Head unit with a fascia adaptor and steering wheel control cables. He removed all these when he sold the vehicle on.
    Would his fascia adaptor be compatible with my car?
    Assuming my JVC KD-R401 is steering wheel compatible, would his cables work with my car?
    TIA
    SBF
    Woodbridge
    Hi mate,
    I am no expert, however, The facia adapter should be fine, however I am under the impression you will need a different steering wheel control lead.
    I am sure one of the electronic guru's will either confirm or correct me.
    Mar 2011
    SomeWhere
    I think what you are looking for is this.
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item43a148cb7f
    The One from your friend is full canbus your Car is half canbus.
    May 2011
    South Yorkshire
    Thanks,
    What do I need to look for on the head unit to confirm it will accept the steering wheel controls.
    TIA
    May 2011
    South Yorkshire
    OK, I have done some digging and it seems that the head unit is not steering wheel compatible so I am going to give this a miss at least for now as this head unit is fine for what I want.
    In regards to the fascia adaptor, are all Vectra Cs the same or do I have to be careful not to get one from the facelift model etc?
    I stripped the head unit out of my previous car, Vauxhall Astra 2001 (Y Plate), will the ISO and Ariel adaptor by the same?
    TIA
    SBF
  1. new head unit at last
    By kenny1zero in forum ICE Gallery
    Last Post: 25th June 2008, 15:50
  2. Want to buy a new Head Unit
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2007, 19:55
  3. New head-unit
    By Christof in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2007, 19:35
