Results 1 to 10 of 16
Thread: Which Bilsteins...
    Regular Member djr69uk's Avatar
    Midlands
    Default Which Bilsteins...
    I'm going to upgrade my suspension set up thanks to knocking which I suspect is a top mount or bearing on one side, and a broken spring on the other. The shocks are probably a bit tired after 119k now anyway so might as well change the lot over.
    My shopping list so far consists of:
    2x top mounts
    2x strut bearing
    1x Eibach Pro 30mm Kit
    So the question is which Bilstein shocks to go for? B4 or B6? If the B4s are the same or slightly stiffer than the standard SRi then that is fine, but if they are softer than the SRi shock then I'll probably go for the B6 instead...?
    Opinions please
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    B6 or B8's are the way to go. B4's are a replacement for standard shocks
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    I've got b4's on 45mm lo springs and there great. Couldent afford b6's
    Midlands
    Quote Originally Posted by s_zigmond View Post
    When you say standard... do you mean non-SRI?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    B4 are spot on. Not to stiff and not bouncy.
    Got B4 and Eibach pro kit 30mm on mine. Think the ride is superb.
    Midlands
    Quote Originally Posted by Graham View Post
    So you had the SRi suspension to begin with... how did it compare to your setup now? I want it 'as new' SRi or slightly firmer than SRi... but not any softer.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Def sharper on the corners with less body roll. The noise has gone over bumps and actually rides them well.
    I would say its better than standard sri set up. But my original springs and shocks had done 100k so probably a little tired.
    All new know so feels great.
    Def a good choice B4s.
    Midlands
    OK thanks mate. Anyone else running B4s and Eibach pros as replacement for SRi standard setup?
    Midlands
    bump.. surely there are a few more out there?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yep me. The ride is far better than Stock SRi. It gives you so much more confidence in the corners and less inside wheel spin coming out of them as well. I actually think the ride quality is better than SRi as well so its win win for me mate.
  1. Ordered my new Bilsteins today !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 14:54
  2. Alternatives to bilsteins
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 21:11
  3. Spoonilocks and the three Bilsteins....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2007, 21:31
