Results 1 to 10 of 23
Thread: steering wheel shaking when braking
    argyll, scotland
    Default steering wheel shaking when braking
    in the past few weeks when i brake quite sharply the steering wheel judders and shakes from side to side, theres no wobble when driving at speeds just when im braking.
    i changed the front pads about a month ago and the rears have plenty left on
    any ideas ?????????????
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Sounds like a warped disc.
    Regular Member Jezzy's Avatar
    S.E
    Could well be worn suspension bushes.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Had this on an old car, turned out to be a comPlety nakerd track rod end.
    argyll, scotland
    ive just replaced the suspension top mount bearings, spring sleeves and drop links about 3 weeks ago ,could i have put a bush on upside down, would that make a difference ?
    is there anyway of testing the track rod ends to see if they are faulty
    i dont think its a warped disc from what i can see
    Nov 2010
    BRECHIN
    To test your track rod ends just jack up 1 side grab the wheel at 9 and 3 and give it a wobble left to right you will feel if there is any play
    Regular Member tappetpaul's Avatar
    Jan 2010
    dundee
    its a warped disk! if it only does it while braking its the disk, if its track rod ends then the wheel can wobble all the time not just when braking
    Nov 2010
    BRECHIN
    You would get judder thru the pedal as well with a warped disk would you not?
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    my truck does this, disc n pads are fine, my wheels go out of balance every few thousand due to how it wears the tyres, i just carry on till it gets really bad then swap the tyres or have them rebalanced
    argyll, scotland
    no pedal judder at all could it be linked to abs ??
  1. Wheel Vibration Under Braking
    By paulhb in forum Suspension, Wheels & Brakes
    Last Post: 13th July 2011, 21:22
  2. shaking steering wheel
    By chrisknights in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 23:32
  3. Steering wheel shaking around 70-80mph
    By stampede in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2010, 16:27
  4. Shaking steering wheel
    By peppered in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2009, 08:19
  5. Shaking steering wheel
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2008, 16:13
vectra c shacking when braking
vectra 1.9 cdti steering shakes when braking
Vectra c shuddering under braking
opel vectra c shudder when braking
vectra c braking shake
