Thread: lowering a c
    Nov 2010
    LEIGH
    Default lowering a c
    whats the difference in springs on a veccy c?
    im looking at lowering my veccy 60mm and there is only 1 set on ebay but it just says 'vectra c'
    mine is a elite 2.2dti saloon if it helps
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Not a good idea dropping it 60mm on standard shocks, I'm dropped 45mm on bilstien,s and occaisonly hit the bump stops. Change shocks as well for the b6's as well I think it is. Sure someone will confirm. Tim
    Nov 2010
    LEIGH
    well the ones ive seen on ebay are uprated shocks fk's i think
    does it matter if i dont get the right ones for mine or are they a different set up for different models of vectra c?
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    You will need to purchase the right springs for the weight of the car. If lowering 60mm You'd be better off buying coilovers. However B8's, if using 60mm drop springs, will be your best option as they are a mono tube designed for large drops.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    I wouldnt drop -80mm. You will hit every speed hump going provided you dont get marooned on it.
    I have -30mm and scrape my under tray sometimes.
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
https:www.vectra-c.comforumshowthread.php136891-lowering-a-c
