Thread: Intermittent loss of power steering......
    Oct 2009
    Belfast
    Default Intermittent loss of power steering......
    2006 1.8 Vectra
    My wife has been having an intermittent loss of power steering, normally when manouvring the car at los speeds with full lock on - before I get the haynes manual out and try to solve it myself, is this common and does anyone know how to troubleshoot the problem efficiently, for example a list of things to check?
    Thanks in advance
    Doncaster
    Think this could be a sign the alternator is on the way mate. Mine was displaying similar symptoms.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    I had simalar synptoms and it was the power steering rack. On my 1.8. They have electronic power steering. Thankfully for me i got it done under warrenty. But heard it was quite a big bill and almost 2 days before got the car back! So fingers crossed its not that m8!
    Full Member Big Sig's Avatar
    Could also just be low fluid.
    Doncaster
    My mate's steering rack went too. Check your track rod ends for fluid as the seals go under the rubber gaitors at the end of the rack and it leaks out from there. Was a swine of a job
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Alternator or battery favorite!!
    Oct 2009
    Belfast
    Thanks for all the suggestions - when I get a chance to try and check these things out I will let you all know what I find.
    kilmarnock
    Regular Member adriano872's Avatar
    Bucharest
    I don't think is the alternator. When u have a faulty alternator, the battery dies in max 15 minutes. I'll go 4 low fluid level or steering fault. The steering is hydraulic and if the fluid is not at the level, it should work very hard..be careful, u could hurt the hydraulic steering pump.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. CDTI 150 Intermittent loss of power/judder
    By Campos1 in forum Engine & Drivetrain
    Last Post: 13th March 2012, 20:07
  3. Intermittent Power Steering problem
    By Marky P in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2011, 12:02
  4. 150CDTI - Intermittent total power loss
    By birdii in forum Engine & Drivetrain
    Last Post: 18th April 2011, 22:16
  5. Intermittent Power Steering Failure
    By sol in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2011, 16:15
loss of steering vectra c
signum intermittent power streering failure
