Thread: Oil filter change 1.9 cdti 150
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Talking Oil filter change 1.9 cdti 150
    Hi all, could anyone give me some general advice on how you drain the oil from the filter before undoing the cannister ? i read some where that you can fit a piece of hose to the filter to allow you to drain it first ! !
    any advice or pic's would be appreciated
    Kcs
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    looking from underneath the car you will see a small plastic tube about an inch long just stick a piece of tube over it this will allow for it to drain into the bowl you used to drain the oil from the sump you cant miss it tbh
    * oh and a little tip put some rags over the exhaust pipe as you will get some spillage so dont possition yourself directly underneath it
    Antwerp, Belgium
    i did it this weekend
    i didnīt know why the plastic tip was so i screwed the whole thing of
    result a lot of oil on the ground
    they couldnīt find a better place to hide the damn filter.
    i also saw that at the side of the filterhousing there is what looks like a lever. is this a draining valve?
    Feb 2007
    Tamworth
    Thanks for info lads, will be under the car for a look in the next week or so,
    INSP1000 is nagging at me !
    cheers
    Kcs
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by sliderke View Post
    No, that lever is for switching between 120 BHP and 150 BHP modes. You switch to 120 mode when driving in countries where only poor quality fuel is available.
    Jan 2010
    wirral
    Antwerp, Belgium
    what kind of an answer is this
    my question was a serious one
    if you can not give a responsible answer then shut up man
    i try to help other people on the forum
    i'd like to have the same effort from others
    S.E
    Get a sense of humour. If everyone in the world was as dull as you I'd ask Navy Seal Team 6 to abseil onto my roof and put me out of my misery.
    Antwerp, Belgium
    if this was meant to be humor.
    ok than. it didnīt send that message out for me.
    No hard feelings from this side.
  1. oil and filter change cdti 150
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2012, 11:22
  2. 3.0 V6 Cdti oil filter change
    By themarbleman in forum Engine & Drivetrain
    Last Post: 26th March 2011, 16:14
  3. Oil filter change on a 3.0 cdti
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 18:40
  4. oil& filter change 1.9 cdti (120) vectra est '05
    By bigsteve in forum Engine & Drivetrain
    Last Post: 8th October 2009, 05:36
  5. 3.0 cdti K & N Filter change
    By M&S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2006, 18:14
vectra c 1.9 cdti oil filter location
vauxhall vectra c 1.9 oil change
vectra c 1.9 cdti oil capacity
vectra c oil filter change
vectra c diesel oil filter install
astra h 1.9 cdti 150 oil change
how to change oil filter on astra 1.9 cdti
oil filter for zafira sri cdti where isit
how tochange the oil on a Vauxhall Vectra 1.9 cdti 2008
zafira 1.9 cdti oil filter location
how change oil and oil filter on zafira 1.9cdti
oil change on a vauxhall vectra 1-9cdti 2006 model
change oil filter vectra 1.9 cdti
vectra C 1.9 CDTi oil filter removal
vectra c cdti oil filter location
oil change on Vectra C 1.9 diesel
remove oil filter cdti 150
astra 1.9 cdti sri oil capacity
08 Vectra timing cdti how to change oil
where is the oil filter on my vectra c 1.9 cdti
how to change the oil filter on a vectra c 1.9cdti 150ps
vectra c 1.9 150 oil change
vectra cdti oil filter location
can I change my Vectra 1.9cdti oil filter without changing the oil
