Results 1 to 10 of 18
Thread: Remove fuse CD70
    Regular Member KeeronMac's Avatar
    Mar 2011
    Donegal
    confused Remove fuse CD70
    How do i remove the fuse for the CD70, think i bricked it, well i know i did, want to disconnect it along with battery over night to try and reset it.
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    The fuse is in the back of the unit mate......Did you try to update with a copied disc by any chance?
    Justin
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by westonprawn View Post
    Justin
    If he did then removing the fuse won't help... what he needs is an authentic firmware update disc from Vx... can't remember the cost but was less than a tenner.
    Jul 2009
    TELFORD
    Quote Originally Posted by jimbojetset View Post
    If he did then hes not alone Lol, Mine stalled half way through I had to stip and remove the disc 5 or 6 times until It burnt at correct speed as it wont eject either!
    Justin
    Mar 2011
    Donegal
    I did indeed gentlemen!! My map disk worked fine so thought why not? BIG mistake obviously!! Am calling in to dealer tomorrow, no point removing fuse then? I tried resetting eeprom but the audio button wont work..
    Mar 2011
    Donegal
    yeah my disk got stuck too! eventually got it out, put original disc (05 version) in and it did the same thing!!
    Aug 2010
    Stoke on Trent
    Don't worry mate I did exactly the same thing... I tried loads of stuff but in the end I bought the disc off Vx... put it in and the unit did the rest... be warned it takes a while to update... I think mine sat there for nearly 15mins seemingly doing nothing but eventually it completed and rebooted and has worked perfectly since...
    Mar 2011
    Donegal
    Fingers crossed just when i was getting into the swing of trying to fix little things with the car, i might leave the rest of my "projects" to the pros!!
    is it ok to leave the screen on all night or should i hook the battery off?
    Mar 2011
    Donegal
    Just so everyone knows, authentic disc from Vauxhall sorted it, very glad to have it back
    Aug 2010
    Stoke on Trent
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. CD70 How to Remove Jog Dial?
    By dlm71 in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2010, 21:24
  3. How do I remove the PCB from a CD70 facia???
    By luke4487 in forum Bodywork & Interior
    Last Post: 16th May 2010, 12:17
  4. How TO Remove The Audio Unit (CD70)
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 15:04
  5. Now having to remove the fuse!
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 23:28
