Results 1 to 10 of 17
Thread: Air con seems to be leaking :(
    Regular Member Knuckle's Avatar
    South
    Default Air con seems to be leaking :(
    Hi all,
    Had my aircon regassed a few weeks ago and it worked great. he sprayed some stuff on the rubbers to see if there was any air bubbles but seemed ok.
    3 weeks and 700 miles later it seems to have run out. I noticed a couple of days ago it was louder than usual and the noise was similar to that of my BMW when that ran out. On the way home today it was blowing out a tiny bit of cold air out of the drivers side vent, then just went completely. the compressor was definitely kicking in when i first started the car, but now it seems non responsive (im told that it doesnt run at all if the level is too low to avoid burning out).
    Any common areas as to where it leaks from? VX just said a new condensor unit, if the problem is over £500. = F*** that.
    Any advice greatly appreciated.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I replaced my condensor... easy job and cost just over £100 for the replacement.
    South
    What steps did you take to realise it was the condesor mate? I would spend £100 but will just suffer without otherwise probably.
    Regular Member DarylAAS's Avatar
    South Shields
    I do the condensors for £136.95 delivered
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'm with Lofty on this one - the most common failure point is the condenser.... being in front of the radiator, it takes all the crap from the road. I've done them on Omegas and Senators now and if my Vectra ends up with this I'll be quite happy to tackle the job myself.
    Take a look through your lower grille at the bottom of it and see if it appears tatty and even damp - a classic sign of failure.
    You could get it diagnosed by an auto aircon specialist and then do the replacement work yourself but that's even more outlay.
    Take a gander here for an idea of common prices:
    http://www.autoairconparts.co.uk/Vau...tors-and-more/
    South
    I will inspect it tomorrow then and see if there is any obvious signs of leakage.
    Thanks for the advice, Daryl is that a VX part and what does it include? Would i need anything else?
    What are these things like to fit? Id be reluctant to buy one until i could be certain it is the problem so if i cant locate it tomorrow it will be a case of taking it somewhere i think.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    If nothings obvious you could be chasing your tail. Mine went, thankfully under warranty, and it wasn't until they but an illuminous dye in that the fault showed up.
    South
    See when i had it regassed he noticed a green dye on one of the rubbers, where it had been tested before.
    dont think there are any air con specialists around here. Not sure where to take it.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Sucks through teeth............Dealer?
    Regular Member Exclusive BV's Avatar
    West Midlands
    thats the problem with these aircon machines.
    how many tyres have you pumped up which seemed to be ok............
    ..........................................and they went down overnight
  1. I am leaking
    By KevinG in forum Engine & Drivetrain
    Last Post: 19th February 2011, 21:29
  2. oil leaking...
    By danman487 in forum Engine & Drivetrain
    Last Post: 6th September 2010, 08:01
  3. Rad leaking
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 20:16
  4. air con leaking
    By nicademus in forum Bodywork & Interior
    Last Post: 7th July 2010, 22:11
  5. leaking air con
    By baz2003uk in forum Engine & Drivetrain
    Last Post: 19th June 2010, 23:38
