Thread: timing chain damage
    uk
    Default timing chain damage
    I'm looking at buying a vec c with a Z22YH engine, apparently the timing chain has gone - fella in the car pulled over and turned engine off when it started to rattle badly and upon restarting, nothing.
    I was wondering if the timing chain has gone, what's the extent of the damage likely to be? If it's a couple of bent valves and cracked guides then I can deal with that, just wondering what the likelihood of piston damage is?
    I've changed a Z22SE timing chain before, and have read posts on here saying chain failure means a new engine, but how far does the damage really extend beyond the cylinder head? Thanks
    Regular Member Jezzy's Avatar
    S.E
    Can the seller prove that he turned the engine off as soon as the rattling started? It's more likely that he tried to get home, and only stopped when the engine died.
    uk
    No proof, but I'd rather go off the experience of other people than take someone's word for it.
    Just wondering if this is worth a look or should I walk away? I don't want to be having to take out the engine or replacing it
    Aug 2010
    Leeds
    Simple work your cost at a replacement engine anything less is a bonus and saving to you.
    uk
    Fair point, how much value would you put on a 54-reg vec c ls with 130k miles?
    S.E
    £2k?
    Aug 2010
    Leeds
    £2k?
    Yes plus engine and you want a decent one plus fitting cost.
    It maybe just a replacement head and away you go.
    uk
    Right will have a look then, I can get the car plus an engine for 1.5k so might consider it. Thanks for the help
    Regular Member Mopar Man's Avatar
    herts
    The dealers throw these engines, after chain failure as they bend rods alot.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yep the yh tend to throw crank bearings ....most the one's ive done have needed engines the z22se was a better engine to rebuild ...... a recon lump from vx are around £1200 .....
  1. z20 net timing chain set up help!
    By tonner in forum Engine & Drivetrain
    Last Post: 16th January 2013, 11:27
  2. Timing chain
    By dave_scarborough in forum Engine & Drivetrain
    Last Post: 27th April 2012, 22:30
  3. Timing chain 2.2 dti
    By tditony in forum Diesel Engine related
    Last Post: 17th March 2011, 03:31
  4. timing chain
    By oldcommando in forum Diesel Engine related
    Last Post: 23rd August 2009, 19:35
  5. 2.2 timing chain
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2008, 15:54
