Results 1 to 10 of 15
Thread: power steering noise ?
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    Default power steering noise ?
    i have a noise coming from the drivers side when my steering is on full lock. i think it has something to do with the power steering
    can anyone one tell me if the repair is covered on networkQ
    Ashington, Northumberland
    What sort of noise? If it is like a groaning noise, check the fluid level. If it's low, then look for leaks. That will be covered under warranty. If it's a knocking, then it's an outer CV joint which again, should be covered.
    Apr 2006
    Leicester
    sort of high pitch grind. but doesnt happen all the time
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    I've got that same noise m8, I'm still trying to work out what it is.
    I'm thinking CV joint, but I hope not.
    Nicking Ya Dinner.
    Might just be the pump exhauster you are hearing, or drivebelt slightly slipping.
    Its an electro-hydrualic system so there is no power steering drive belt to slip..
    Check the fluid level, it may be running short of fluid.. Either that or if it starts to grind all the time expect Pump trouble and a sizeable bill..
    Get the fluid checked for level and colour and above all try no to hold the steering on full lock for more than a few seconds as that really abuses the pump..
    Regular Member SirGSi's Avatar
    England
    Hi guys.
    Does anyone know whereabouts the PAS reservoir tank is - anyone got any photos to show us please?
    Grant.
    On the GSi it is located beneath the drivers side headlight assembly..not the easiest to get to..
    whiteish canister with a black cap..
    May actually be easier to remove the bumper to access the reservoir.
    Other cars like my old man's 19cdti and C's old 2.2 had the reservoir located on the top of the rack, middle of the engine bulkhead..much easier to get at..
    Strange, mines a 2.0dti and the pumps under the headlight too
    prob because if they put it on the rack at the back of the bay it would only be a few inches off the turbo, so the plastic reservoir might get a little hot..
    thats the reason they relocated it on the V6..it's too tight to the back exhaust manifold..
    the 2.2 Petrol has more airspace around it to keep the reservoir cool and the turbo on the cdti 1.9 is on the front of the engine.
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. whirring noise from power steering
    By Matt_Bankier in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 21:48
  3. Help!! Power steering making strange noise
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 22:19
  4. Power steering pump noise - brand new car
    By Jaffatubes in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2007, 09:55
  5. Power steering noise
    By wylieeeeeeeee in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2007, 20:40
is power steering fluid leak covered under warranty vauxhall vectra
