Thread: oil usage
    Regular Member jasonblake's Avatar
    Middlesbrough
    Vehicle : Insignia Tourer
    Trim : SRI NAV
    Engine : 2.0CDTI 160BHP
    Year : 2012
    Mileage : 29K
    Default oil usage
    hi all
    over the weekend the oil light appeared on my dash of my 3.2vec c elite and when i checked the oil it was empty it was 6000 miles since the last oil change and to be honest i have never checked it since.
    any verdicts
    if it was an oil and filter change , they may have filled to the top line and checked it before running the engine for a few minutes
    if they hadnt run the engine then although it would show full on the dipstick the filter housing would be empty
    so when its then been run it would fill up the housing thus losing some level on the dipstick
    or it just wasnt filled with correct amount of oil
    Regular Member Jezzy's Avatar
    S.E
    From now on check it every two weeks - when the oil light comes on, it can be too late....
    Aug 2010
    Leeds
    I assume you have no leaks?
    The onus is on you to check it regardless if a garage filled it to the correct spec or not.
    Me i wash the car then vac it out at least once a month then check levels.
    Handbook states every week for checking depends on mileage, Lesson learnt id say.
    Middlesbrough
    Trim : SRI NAV
    Year : 2012
    Mileage : 29K
    the thing is i always, well used to check things like that suppose just got abit lazy but yes i do alot of miles so it will be worth checking in the future lol
    there is no obvious leaks anywere either
    on my last v6 the 2.5 sri it never used any oil at all inbetween services
    My previous Vectra B 2.0 would use 1 litre every 8K miles, meaning I had to top it up just before the next service
    My current Vectra C 3.0 V6 CDTI uses about 1.5 litres every 12K miles, so again means one top up before the next service
    In a petrol you should be checking the oil weekly, every fifth use of the car, or every 1000 miles
    In a diesel it is strictly weekly
    Also note Vauxhall advise that the engine can use the amount between MAX and MIN each 1000 miles, which they consider normal
  1. 3.2 V6 Oil Usage
    By jasonblake in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2015, 15:54
  2. Internet monthly usage.
    By gtr1000 in forum The 'Off Topic' room
    Last Post: 1st December 2012, 21:57
  3. 1.8 vvti oil usage
    By nicademus in forum Engine & Drivetrain
    Last Post: 1st March 2010, 21:18
  4. fuel usage
    By slugo in forum Vectra C / Signum Troubleshooting
    Last Post: 31st December 2006, 00:26
  5. 2.2 petrol - oil usage
    By malhudson in forum Engine & Drivetrain
    Last Post: 1st February 2006, 13:08
