Results 1 to 10 of 15
Thread: Grooved Disc Front & Rear - Which direction?
    Apr 2009
    Aalborg
    confused Grooved Disc Front & Rear - Which direction?
    Hi guys,
    My pads were worn and so were my discs so I decided to uprate my 2.0T braking power by using some grooved discs.
    I have got them on the car now and have tried to find a definitive answer if they are the right way round but can't ... so please take a look at these pictures and let me know if they are the correct way around.
    TIA
    Alistair
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Front is correct, swap the rear ones over.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by awilson View Post
    Hi guys,
    TIA
    Alistair
    http://www.vectra-c.com/forum/showthread.php?t=111228
    Try this thread it has the answer.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    lol i looked into this when I put some on,,, some say one way, some say another... I went with the direction you did your fronts and have had no problems at all...
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Check this out,
    http://www.brakedepot.co.uk/shop/cmspage.php?page_id=13
    Most brake disc are the same the grooves move hot gases and brake dust to the outside of the disc.
    Full Member paul.sessions's Avatar
    leighton buzzard
    as said the fronts are correct the rears need swapping over
    Glasgow
    As the guys said above just the rears need swapping.
    Full Member Big Sig's Avatar
    I fitted a set of black diamond disks years ago, it said in the instructions that it depended on the amount of grooves the disks had.
    Trim : Sport
    Engine : Petrol
    As a rule of thumb go with the direction of the wheel rotation. As mentioned only the rears need changed.
    Apr 2009
    Aalborg
    Perfect guys, thanks for your help ... I will have to swap them around tomorrow
  1. Mtec Grooved Disc
    By amand in forum Suspension, Wheels & Brakes
    Last Post: 17th September 2011, 21:15
  2. Drilled and grooved front discs
    By soulie in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2010, 20:53
  3. Drilled and grooved front+rear discs
    By mucklestone in forum Handling & Braking
    Last Post: 17th August 2009, 19:59
  4. Grooved Disc Brakes
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 22:45
  5. Can i get Front Drilled and Grooved Discs
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2006, 14:41
