Results 1 to 3 of 3
Thread: Headlamp leveller motor
    Apr 2009
    Norwich, UK
    Default Headlamp leveller motor
    Can anyone help me with this one?
    Whilst fiddling with the headlamp during a lamp change, I removed the level adjuster motor - simple anti-clockwise turn an out it popped. I was curious what it was!
    However, on replacement, headlamp beam was pointing to the sky! Is there a correct way to fit the motor?
    I have checked the lamp is fitted properly, but will now have to wind the adjuster to get the beam anywhere near right, then pop in somewhere to get it adjusted properly.
    Thanks in advance.
    Roger
    Engine : 1.9 CDTi
    The motor 'slides' in so you need to put it in at an angle then clip it in properly.
    Apr 2009
    Norwich, UK
    Yeah, I seem to see how it goes back in. Locate and push in then turn clockwise till it clicks in place. I'm wondering if it hasn't located with the internals of the headlamp properly.
  1. Headlamp washer's
    By wardy23 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2013, 22:44
  2. Automatic headlight leveller help needed
    By leeroberts919 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2010, 17:01
  3. headlamp level
    By davidj387 in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2009, 01:00
  4. MOT - headlamp insecure
    By tonydee in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2008, 19:14
  5. Headlamp washers
    By Jconnors in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 13:38
