Results 1 to 10 of 15
Thread: Air con vs windows.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    Default Air con vs windows.
    Now the good weather is here, I have been wondering....
    Obviously putting air con on reduces mpg, but is it better or worse than winding down windows? My personal feeling is that at low speeds <30mph having windows open is better choice as far as economy goes, whereas at high speeds its better to preserve the aerodynamics and put air con on. I could have this totally wrong tho......
    Actually as I'm writing this a light bulb has gone on in my head....is that the point of wind deflectors then? So you can open windows without increasing drag?
    Any thoughts?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Mythbusters did one on this ..... granted their results were based on US systems, etc but the result seems plausible enough :
    Up to about 50mph - aircon off uses less fuel as drag from open windows had insignificant effect on mpg
    Over about 50mph - aircon on as closed windows caused less drag
    Sep 2009
    Glasgow
    my aircon is on all the time and easily get 47-48 mpg with hard driving
    Glasgow
    The larger the engine the less of an impact on mpg is another one. A large engine ticks over with aircon on with ease where as a smaller engine will have more load on it.
    Dec 2010
    Southport
    thats inteeresting . Pretty much how I suspected then. To be honest, neither seems to make that much difference.
    Regular Member robengland9's Avatar
    Feb 2011
    london
    to me its no so much about the mpg....its much quieter with the windows closed.. try to listen to your radio at 50mph with windows open...its not good
    May 2006
    scotland
    And switch the radio off for another small saving
    Sodding Typical on Sea
    I use AC all the time as well as suffering hayfever the pollen filter works very well for me plus I really have never seen a drop in economy.
    I am baffled by people running about with windows open as unless AC ir run regularly it means BIG bills in the short term,,,
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Even with a 1.8 I have not noticed any drop in mpg using A/C.
    Dec 2010
    derby
    AiR con all the time for me,my car has climate control so just set the temp and let it do its work
  1. Its doing my nut in (windows)
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 14:39
  2. Windows 7
    By steve1975l in forum General Chat
    Last Post: 17th June 2009, 16:33
  3. Windows Wipers and Windows Washers
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 09:58
  4. Do your windows go down on their own???
    By Pepsi Max in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2009, 22:27
  5. dvd,windows,help.
    By wernham in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2008, 23:23
